Hatch Closing Issue
Old Jun 10, 2006 | 11:46 AM
lightning30's Avatar
lightning30
my friend has to slam it to
Old Jun 10, 2006 | 12:12 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
good reason to visit Top Down Tech and get a window valet.
I use the emblem to close the hatch and have yet to have a problem in almost 5 years
Old Jun 10, 2006 | 01:27 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Originally Posted by kawboy5792
I was just wondering if this is normal: when all the doors are closed and the windows are up, i have to give the hatch a pretty good slam to get both catches to close...when the doors are open or the windows down the hatch almost closes itself. Plus, sometimes when i slam the hatch, the change in air pressure causes one of the windows to pop over the roof retainer...any thoughts?
Don't SLAM the hatch. Gently push it down with some weight.
Don't SLAM anything, it's bad form.
Old Jun 10, 2006 | 01:41 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Slammin it is not good!
Old Jun 10, 2006 | 01:47 PM
doug doo wop's Avatar
doug doo wop
Old Jun 10, 2006 | 02:14 PM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
Old Jun 10, 2006 | 03:35 PM
GrayC5's Avatar
GrayC5
Originally Posted by 4GTABODT
I've never heard of this either... is this "valve" located on the floor portion or the rear wall of the trunk?
Originally Posted by BiggieBoy
You learn something new every day. I never knew this thing exhisted----where is is located again?????? Any pictures available???
The valve is located on the side wall panel, immediately behind (to the rear of) the driver's side wheel well. All C5s (coupes, verts, FRC/Z06s) have them. The one on our car looks like the valve frame is made of whitish plastic and is approximately 4" square. When you pull the side carpet back, you should see it. Sorry, don't have any pics.
Edit: Actually, I do have a pic. See my post below.
Old Jun 10, 2006 | 04:09 PM
GrayC5's Avatar
GrayC5
Although it's not very good, I did find this pic from when I was adding sound deadening to our car. If you look at the very left side of the pic, not quite mid way down (to the rear of the top of the wheel well), you will see the relief valve. The frame of the valve is more rectangular than square as I first described and it is grayish in color in this pic.
HTH
Old Jun 10, 2006 | 04:26 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
I use the TOP TOWN to raise up the windows after I shut the lid.
Old Jun 10, 2006 | 06:10 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Great info---Thanks
Old Jun 10, 2006 | 06:50 PM
BuckyThreadkiller's Avatar
BuckyThreadkiller
Successful Plumber
From: Top of the hill, 3rd mailbox on the right. Texas
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
The only thing the valve is good for is to have a place to run the cable for the XM antenna from the tail light to the head unit.
Old Jun 10, 2006 | 06:55 PM
SPS's Avatar
SPS
You learn something new every day ! Thanks for explaining what that is. I don't see how the "valve" could possibly malfunction - its not so much a valve as as air passage. I pulled back the carpet to see if the carpet was resticting the airflow, but that seemed to have little effect. I have the same problem as kawboy --- if I slam the hatch, the windows pop out from the roof seal ---- took me a while to figure out how rain was getting in the car --- if I closed the doors then the hatch, the windows would pop out --- then if it rained, water would get in the car
Steve
Old Jun 10, 2006 | 06:56 PM
  #33
ebubman's Avatar
ebubman
slamming on a c5 = bub
Old Jun 10, 2006 | 08:11 PM
  #34
GrayC5's Avatar
GrayC5
Steve
It has been sometime since I've looked at the pressure relief valve, and I couldn't remember exactly how it and the flaps were constructed. In looking at it again and the GM Service Manual, I have to agree with you in that I don't see much either that could go wrong with the valve itself to prevent air passage. My other thought was that perhaps some obstruction was preventing air flow through the valve. Too, the valve and its location don't appear to be of the best design and one would think that the carpet would restrict some air flow to the valve. But then, you said you had pulled back the carpet and found this to have little effect.
Also, I would think that the larger surface area of the coupe hatch would generate quite a bit more cabin air pressure and a problem that is much more prevalent to the coupe. Anyway, now that the folks know that the valve is there, perhaps one of the innovative people on this Forum may come up with a solution for you coupe owners. Best of luck to you guys.
Old Jun 11, 2006 | 01:17 AM
  #35
kawboy5792's Avatar
kawboy5792
Steve
One thing i found to help that problem is changing the window angle...i had a little more wind noise than i liked, and had to fix a window rattle anyways, so i tilted the top of the window inwards a little bit while i was in there. Not only did the wind noise decrease (and no more tiny drip when it pours), but the window doesnt pop over the retainer quite so much any more....only does it on the driver side now. i guess ill just keep to the latch and press method on the hatch.
Old Jun 12, 2006 | 03:43 AM
  #36
DocPapillon's Avatar
DocPapillon
Gently close deck till touching, heel of hand on emblem, gentle push, Yeah!
Old Jun 12, 2006 | 06:20 AM
  #37
With the windows up and the doors closed, mine does the same thing. There is just a lot of pressure inside the car. I just gently lay my hatch down and then push firmly on the emblem and it closes.
Old Jun 12, 2006 | 06:47 AM
  #38
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Thanks Jim I'll have to check mine out...learn something new everyday...never knew these puppies even had one of these...Thanks
