Hatch Closing Issue
Old Jun 10, 2006 | 01:27 AM
kawboy5792's Avatar
kawboy5792
Default Hatch Closing Issue
I was just wondering if this is normal: when all the doors are closed and the windows are up, i have to give the hatch a pretty good slam to get both catches to close...when the doors are open or the windows down the hatch almost closes itself. Plus, sometimes when i slam the hatch, the change in air pressure causes one of the windows to pop over the roof retainer...any thoughts?
Old Jun 10, 2006 | 01:43 AM
GrayC5's Avatar
GrayC5
In the rear compartment on the drivers side, pull back the side carpet and you should see a square shaped (cabin) pressure relief valve. Check to see if it is working properly. If not, it may need to be replaced. For a '99 coupe looks like GM Part # 10285751. Good luck.
Edit: Just noticed, but it looks like the above P/N has been replaced by P/N 10339669. You may want to verify correct P/N with your local dealer.
Old Jun 10, 2006 | 01:49 AM
BrianWe's Avatar
BrianWe
Sounds pretty normal to me. My 2004 coupe has been that way from day 1. Just press down on the emblem to push the hatch all the way closed. That way you don't fingerprints everywhere.
Old Jun 10, 2006 | 01:51 AM
DaBoz's Avatar
DaBoz
You could try placing your hands on both sides of the hatch and gently but firmly pressing down to latch.
Old Jun 10, 2006 | 02:12 AM
ericdwong's Avatar
ericdwong
Leave a door open when closing the hatch and it will close easy.
Old Jun 10, 2006 | 03:30 AM
kawboy5792's Avatar
kawboy5792
alright, thanks guys, ill check the valve but probably just the way it is...i never really noticed that you dont have to even apply any force when the door is open...it just kinda pulls itself closed. (as mentioned above...i usually just latch it then press on the emblem)
Old Jun 10, 2006 | 03:31 AM
edensknight's Avatar
edensknight
OR, try this: Leave a door open, then still close hatch gently. Frankly, there is no need to SLAM the hatch.
Old Jun 10, 2006 | 04:05 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i must admit, i have never, ever heard of this before...i'll have to check for that valve.
Old Jun 10, 2006 | 05:47 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I've never slammed mine shut. Just lower it until it rests on the latches, place a hand above each latch and press. It latches nice and easy, no stress on the hatch or latches, and no air issue.
Old Jun 10, 2006 | 05:56 AM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
I've never heard of this either... is this "valve" located on the floor portion or the rear wall of the trunk?
Old Jun 10, 2006 | 06:19 AM
Joe C's Avatar
Joe C
Old Jun 10, 2006 | 06:45 AM
ebubman's Avatar
ebubman
agree w/ the others that this is perfectly normal. we close the hatch gently &, fingerprints notwithstanding, push gently down in each corner to latch securely. bub
Old Jun 10, 2006 | 06:58 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
I treat her gently. She likes it that way
Old Jun 10, 2006 | 07:42 AM
Dark-Knight's Avatar
Dark-Knight
I've had to leave one of the doors open when closing the hatch since I bought this '04.
Old Jun 10, 2006 | 08:03 AM
Tom/99's Avatar
Tom/99
I always open a door prior to closing the hatch. I don't like having to slam it, to get it to latch
Old Jun 10, 2006 | 08:19 AM
C5 4 ME's Avatar
C5 4 ME
Old Jun 10, 2006 | 08:47 AM
KemahC5's Avatar
KemahC5
To Hatch Closing Issue
Old Jun 10, 2006 | 11:16 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
You learn something new every day. I never knew this thing exhisted----where is is located again?????? Any pictures available???
Old Jun 10, 2006 | 11:25 AM
JH's Avatar
JH
Hmmmmmm. I usually ease my hatch down and push it lightly to secure it. No slamming. And I NEVER push on the emblem. They will more quickly decide not to stay stuck in the car if you push on it whenever you close the hatch. I wonder if some adjustment in yours is warranted, so you don't have to slam it?
Old Jun 10, 2006 | 11:44 AM
the Vetteman3's Avatar
the Vetteman3
According to my previous owner, thats just due to the integrety of the seals- they seal the car up so well that you are fighting the air pressure. Of course, if this is the case, and if there is a cabin pressure release valve, either mine isn't working, or it is set to release at a pressure greater than what it takes for me to close the lid. At any rate, all I do is gently press it down with my palms and it closes, just be firm but gentle.
Frank
