Targa Top Creaking!!
Old Jun 11, 2006 | 12:57 AM
MagRed_00's Avatar
MagRed_00
Default Targa Top Creaking!!
I've noticed my top start creaking pretty bad in the last few weeks. I have done the following:
1. Dielectric Grease on all weather-stripping
2. Tightened visors thinking I would get lucky
3. Tightened the rear latch which I think actually made it worse
How do I get rid of this creaking? I am pretty sure it is coming from the passenger side latch and I know there was a post on how to tighten it somewhere, but I can't find it with the search button.
Thanks in advance.
Old Jun 11, 2006 | 02:02 AM
vetterlatethannever's Avatar
vetterlatethannever
Old Jun 11, 2006 | 02:36 AM
GOZ2FST's Avatar
GOZ2FST
Have you put some grease (any kind) on the bearing surface of the latch itself? This worked for me.
Old Jun 11, 2006 | 09:19 AM
BT-01-vette's Avatar
BT-01-vette
I stopped my creak permittly by repostioning the front latches that are attached to the windshield. With the top off on the front latches at the top of the windshield, look dn from the top and pull back the plastic and you will see 2 screws (if memory services, 10mm wrench). Loosen them and push the latch mech. dn. just a tad and keep it level. Do both sides and tighten the screws back up. Put the top back on to make sure it's not sitting too low, If so them go back a raise them them a bit. Don't over tighten the rear latch. This is the only way to stop the creak! Grease this and grease that will not stop the creak, it will come back. Good luck
Old Jun 11, 2006 | 09:31 AM
Oldvetter's Avatar
Oldvetter
Here is the procedure for adjusting, good luck !
Corvette Targa Top Adjustment
Roof Lift Off Panel Adjustment
1. Perform one or more of the following five adjustment procedures to properly align the roof lift off panel.
2. To adjust the front striker for up down roof alignment perform the following steps:
3. Remove the windshield upper garnish molding. Refer to Windshield Upper Garnish Molding Replacement in Interior Trim.
A. For major up down roof adjustment loosen the striker bolts and reposition the latch striker up or down.
B. For minor up or down roof adjustment loosen the striker outboard bolt and slightly loosen the inboard bolt, pivot the striker on the inboard bolt in 2 mm (0.08 in) increments up or down.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
C. Tighten the striker bolts. Tighten
Tighten the roof front latch handle striker bolts to 10 N•m (89 lb in).
D. When the striker is properly adjusted the handle will snap closed.
4. Install the windshield upper garnish molding. Refer to Windshield Upper Garnish Molding Replacement in Interior Trim.
5. To adjust the front latch handle forward or rearward perform the following steps:
. Loosen the latch handle bolts.
A. Position the latch handle forward or rearward. Maintain a minimum of 2 mm (0.08 in) clearance between latch handle and the latch striker to avoid squeaks and rattles.
B. Assure the latch handle base is parallel to the striker to provide clearance to the sunshade mirror door.
C. Tighten the latch handle bolts. Tighten
Tighten the roof front latch handle bolts to 13 N•m (10 lb ft).
6. For major rear latch adjustment adjust the rear latch striker performing the following steps:
A. Remove the roof lift off panel.
B. Remove the roof bow center interior trim panel. Refer to Trim Panel Replacement - Rear Roof Bow in Interior Trim.
C. Loosen the rear latch striker attaching bolts.
D. Adjust the position of the latch striker forward or rearward for major adjustment.
E. Tighten the striker attaching bolts. Tighten
Tighten the roof rear striker bolts to 10 N•m (89 lb in).
F. Install the roof lift off panel.
7. For minor rear latch adjustment, adjust the latch handle hook one turn at a time to achieve moderate pressure to the latch as follows.
A. Loosen the set screw locking the latch hook.
B. Turn the hook in to tighten or out to loosen.
C. Tighten the set screw.
D. Install the roof panel.
8. To adjust the rear locator perform the following steps:
. With the roof installed on the vehicle loosen the locator mounting bolts.
A. Reposition the locator.
B. Tighten the mounting bolts. Tighten
Tighten the roof rear locator to locator bracket bolts to 10 N•m (89 lb in).
Old Jun 11, 2006 | 10:44 AM
MagRed_00's Avatar
MagRed_00
Notice
Wow,
This looks like it could do the trick. My driver side latch gives a nice "snap" into place when you close it, but the passenger does not. What is the windshield upper garnish panel and how do you remove that? I can just see myself breaking something plastic while tearing this apart
Old Jun 11, 2006 | 02:44 PM
00247's Avatar
00247
I use a 10mm craftsman ignition wrench for the front latches. It is a small open end wrench that is straight on one end and has the jaws at 90 degrees angle on the other. It is very thin and will access the bolts without removing the trim. If the bolts have been over tightened, then you may have to take it off.
Old Jun 11, 2006 | 06:39 PM
MagRed_00's Avatar
MagRed_00
Cool,
I had a 10mm that worked laying around the house. Seems to fix the problem as I could shake the top and hear it creak before and now I can't. Thanks for all the help.
To Targa Top Creaking!!
