Halltech Stinger Intake Question
Old Jun 12, 2006 | 02:38 PM
CVG323's Avatar
CVG323
Default Halltech Stinger Intake Question
will a halltech stinger from an 03 Z06 work on a 97 coupe?
i have a friend whos selling me his and i want to know if everything is compatible... like MAF sensor or whatnot.. im fairly new to the vette world, so take it easy on me..lol
Old Jun 12, 2006 | 02:46 PM
Dave68's Avatar
Dave68
I believe the MAFs were increased in size in 2001. The Stingers come in two sizes, smaller for 97-00, and larger for the 01-04s.
Old Jun 12, 2006 | 02:51 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
That's right, it's pretty easy to use the larger style on the smaller maf's but, not so much going the other way.
Old Jun 12, 2006 | 03:36 PM
CVG323's Avatar
CVG323
so if i put the stinger from a 03 Z06 on my 97 coupe, it will work fine? i wont get any errors or check engine light?
Old Jun 12, 2006 | 04:02 PM
Dave68's Avatar
Dave68
I'm not sure if Stang has done this successfully before; I have not. All I can tell you is that as long as there are not any air leaks, you won't get any lean codes or other messages. The 97-00 Stinger air bridges either have a hole or require one to be drilled in to accomodate a sensor that is in your OEM airbridge. If you DO use the newer version, you WILL have to drill the hole, yourself.
I recommend that you also ask Halltech. Info can be found here:
http://www.corvettec5.com/store/?pag...f2a8d09eed4fb8
Old Jun 12, 2006 | 04:12 PM
CVG323's Avatar
CVG323
thanks Dave68. im gonna call them during my lunch break and find out whats up, because im getting a stinger for $100!
i dont wanna pass that one up
Old Jun 13, 2006 | 12:45 AM
CVG323's Avatar
CVG323
TTT
more info needed...
thanks for everyone who has replied. i cant call stinger guys cuz im just too busy @ work... and when i get home im too tired to call them... thanks guys in advance
Old Jun 15, 2006 | 01:27 AM
CVG323's Avatar
CVG323
TTT once again
Old Jun 15, 2006 | 07:11 AM
cenzo's Avatar
cenzo
Cris, you'll have to verify this with Halltech, but since your MAF sensor is smaller than your friend"s, neither the airbridge nor the warhead filter will fit your MAF sensor.
Old Jun 15, 2006 | 11:55 AM
CVG323's Avatar
CVG323
thank you for the reply, and im not going to buy it anymore. its not compatible for my car.
Old Jun 15, 2006 | 12:25 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Jun 15, 2006 | 04:43 PM
Hardhead's Avatar
Hardhead
You still should be able to make it fit, stangkiller has done this before i believe and everything worked fine.
To Halltech Stinger Intake Question
