Gas guage problem...
Old Jun 12, 2006 | 03:10 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
Default Gas guage problem...
I keep gettin the "Low Fuel" on the DIC. but i filled up a full tank and still it reads low. Is this the sensor or the sending unit? any ideas?
i hear this is a common problem on the early Vettes. mine is a 98'.
how much to repair? how much time is usually involved?
any thoughts...
thanks guys!
Aj
Old Jun 12, 2006 | 04:02 PM
Yellow 2000's Avatar
Yellow 2000
I had the memory flashed at the dealership and mine has worked fine since. Use good gasoline, I use Chevron but I have heard Shell is good also.
Old Jun 12, 2006 | 04:05 PM
Yellow 2000
To answer the rest of your question it took a few minutes and the dealer, Jon Hall Chevrolet in Daytona Beach didn't charge me. They were doing the column lock recall at the time. Great people to deal with. They have one technician dedicated to Corvettes.
Old Jun 12, 2006 | 06:55 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
yea....im sure its not a re-flash issue.
anyone know what kinda additive i can put in to try and clear out anything gumming up the sensors? I heard this may also work? i do not want to buy a new sending unit, as it is 420 for Left tank and 390 for the right tank... thats nuts!!!
Aj
Old Jun 12, 2006 | 07:33 PM
Cheech Wizard's Avatar
Cheech Wizard
Go to Chevron and get this:
Old Jun 12, 2006 | 07:41 PM
trussme's Avatar
trussme
Default This Should Work
Buy the Large size(for up to 20 gals.) TECHRON (by Chevron) additive at your Auto Zone or comparable auto parts dealer & dump it in your nearly empty gas tank...one or two of these treatments should clean up those sensor deposits & return your gas sending unit to normal operation....it fixed mine. BTW, do this every other tank full & you should remain trouble free ....
Old Jun 12, 2006 | 07:50 PM
jim49tx's Avatar
jim49tx
Have a 98 also. Gauge messed up a few times so I added the Techron.
No problems now. If it resurfaces then I will just add a bottle and I am good to go again.
Just my 2 cents.
Jim
Old Jun 12, 2006 | 08:01 PM
StealthZ06's Avatar
StealthZ06
I'm having the same problem. I did a search and read to put some Techron Fuel System Cleaner in. I got a bottle, but am waiting before getting lower on gas before I try it (as per the directions on the back).
http://forums.corvetteforum.com/foru...e=2&order=desc
To Gas guage problem...
