[Z06] LS2 and LS6 diffences
Old Jun 14, 2006 | 05:58 AM
blandcastle's Avatar
blandcastle
Default LS2 and LS6 diffences
Hey guys, what is the difference between an LS2 and an LS6 engine? I am just curious, but I am sure that some of you know. Thanks guys!
Old Jun 14, 2006 | 01:32 PM
zeevette's Avatar
zeevette
The biggest difference is the bore being 4.0 on the LS2,(6.0 liter) and 3.898 on the LS6. The block is said to have thicker casting around the cylinders, and generally a better base for a performance build. Other differences include intake manifold and knock sensor locations. I believe the heads are the same.
Old Jun 14, 2006 | 01:44 PM
CYA-Vett's Avatar
CYA-Vett
Yep, heads are the same.
The cams are diferent.
I believe all the other parts are interchangeable except:
Front cover
Valley cover
Timming set
Timming chain damper
Old Jun 14, 2006 | 07:11 PM
blandcastle
Thanks alot guys. I really appreciate your replies.
To LS2 and LS6 diffences
