'02 Has Tapping Engine On Warm-up
Before I get flamed about not using Search, I tried but all I get when I try to go to Search is the ole "This page cannot be displayed" sign.
Can anyone give me info about this problem and where to locate the service bulletin?
From what I understand, the cylinders were designed with just a little bit of extra space and so it takes a few moments for the pistons to warm up and expand enough to eliminate that extra space and for the noise to go away.
It bugged me at first and I did all the usual complaining to GM and all I got was a 100,000 mile engine/powertrain warantee in case it ever does kill the engine, so to speak.
Just gradually warm up your car by drivinig slow and easy for the first few minutes or so and you shouldn't have any problems. For more info, do a Google search for "Piston-Slap."
I would NEVER run any of the 0-5, 0-10, 5-10, 10-20, or 0-20 oils that are so popular these days, regardless of brand, in ANY vehicle I own. They may be good for short term reduced spinning friction, and hence good for higher milage ratings, but my expert engine builders tell me they are terrible for engine protection and long life.
I DO suggest following the advice to use a high quality synthetic oil, as they as a 'family' of oils seem to have far better resistance to heat breakdown, maintain lubricity longer, and deal with contaminates better than regular refined motor oils. Besides Mobil One motor oils, I have a lot of experience with Red Line lubricants and oils and can strongly suggest either one. There are some other brands of synthetics promoted here on the forum that offer lots of test data to proove how good they are, but I do not know if they make any products in the viscosities that are usefull for engine life.
Good Luck!
Okaaaaay.....
Back in my Lotus days in the 70s, I had several custom built engines for my S2 Europa. There weire fitted with Arias custom made forged pistons, and they too slapped until they warmed up. Arias and my engine guys told me way back then that the strongest piston alloys have a higher rate of thermal expansion coefficent, so to fit right when hot, need to be a little loose when cold. This is exacly the condition in the LS engines too.
I agree that the LS1 and 2 are the best small block chevy ever produced. A lot of people are blowing or spraying these engines in stock form up to 500 or more HP and they still hold together. With stronger crank, rods, and pistons, and a bottom of block brace, they can hold 1000 or even more HP. Amazing for a production aluminum small block pattern
I still stand behind 20-50 weight oils, but at least you are not running that water weight crap. Just take it easy on the engine revs and loading until regular operating temps are reached and you should enjoy great service life. This is reasonable advice for any engine, not just LS engines.
If you had a bad O-ring in your oil pump you would really notice the tapping at cruising speeds, because it starves your lifters of oil. I know. Don't waste a butt ton of money looking into your $3 o-ring for a fix. Try a few of the other suggestions first, like the oil change.
If the car still has a stock oil pump and o-ring in it, that is highly not likely to be your problem area.
That is just my .02 cents worth.
Micah
