Door lock problem
Old Jun 16, 2006 | 10:01 AM
Jake the Snake's Avatar
Jake the Snake
Default Door lock problem
After playing with my DIC the other day, setting the options the way I wanted them, I noticed that the drivers door would not lock with the key FOB or by pressing the lock/unlock switch. It makes a clicking sound like it locked and the lights flash etc, but the door will open and the alarm goes off. The door will lock with the key and manaully by pushing the lock and the FOB will unlock the door. Passenger door lock works OK. Any suggestions on what to look for or a fix?
Old Jun 16, 2006 | 10:05 AM
Hrdtop00's Avatar
Hrdtop00
I had a very similar problem in my car. It turned out to be the EDCM in the drivers door. I purchased one from Gene here on the forum.
Old Jun 16, 2006 | 10:08 AM
brokebyducati's Avatar
brokebyducati
what is the EDCM and how much does it cost?? how tough is it to replace?
Old Jun 16, 2006 | 10:19 AM
jdmvette's Avatar
jdmvette
Night Owl for life
a "new" module from a parts car solved the same problem for me.
i got it for $50 shipped.
Old Jun 16, 2006 | 11:32 AM
rws.1's Avatar
rws.1
I belive it is called a door control module ( DCM). One is for the drivers door a different one for the passenger door.
There are at least 4 possible problems that can cause your issue.
1.a short in the wiring or loose connections to the module
2.a bad relay in the module ( generally this means the fob does not unlock but the door button does) digi-key sells the relays for under $2 and a radio repair shop can remove it and resolder it
3. the circuit board is shot need a replacement DCM ( $50 used or approx $400 new from the stealership
4. the problem is not the DCM but the lock actuator.
good luck tracking it down
Old Jun 16, 2006 | 12:30 PM
Jake the Snake
Thanks for the information!
Old Jun 16, 2006 | 02:26 PM
GrayC5's Avatar
GrayC5
I think he means LDCM - Left Door Control Module.
Old Jun 16, 2006 | 02:37 PM
southernshark's Avatar
southernshark
sorry it my inner 8yr old flared up on me
Old Jun 16, 2006 | 05:47 PM
FASTRC5's Avatar
FASTRC5
6th Gear
Default Chasing Gremlins
I have been chasing gremlins myself the last couple of days. I have isolated the problem as a bad ground. (I have full system outage of LDCM, no comm...) Is the code the DIC pulls. I don't think that is what your problem sounds like. First pull the codes by holding down option and pressing fuel 4 times. Write down any codes for the LDCM of RDCM. the codes change every year but they are posted various places around the internet. If that didn't tel me anything useful I would hot wire directly to to lock actuator bypassing the module. If that doesn't trigger your latch you need a new latch. Going throught the wiring diagram checking power and grounds is the next process. As other members have stated it could just be your DCM which is about $180 for a new one from gm-car-parts.com
Hope It helps.
To Door lock problem
