[Z06] Dyno pull ???
Old Jun 18, 2006 | 02:20 AM
99CorvetteFRC's Avatar
99CorvetteFRC
Default Dyno pull ???
My first dyno pull
HP 333 Torq 336 1999 FRC K&N No mufflers Stock Not to bad I guess??? ABS light Active handling lights both came on and it quit pulling at 5000 128MPH RPM Why? Is this normal? But no where near my friends 556 HP 648 Torq Viper So now what can I do for more power and more speed in the 1/4 mile on a small budget? NO tune nothing done at all ......STOCK.....Dynotec portable chassis dyno I think my car was one of the lowest powered there. NO Z06 was there what are you guys pulling???
Old Jun 18, 2006 | 09:58 AM
AutoMag's Avatar
AutoMag
Pulled 370/357 with my showroom stock 03 Z06. I believe that is considered to be on the high side of the curve.
Old Jun 18, 2006 | 10:18 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
That seem quite high for a bone stock Z06.
Old Jun 18, 2006 | 12:08 PM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
ABS light can come on on no belt linked AWD dynos but will go away under normal driving.
I dynoed Automag's Beautiful Z and the stock power was awesome, highest stock C5 to date, most 02-04's we see about 360-363 on the high side. At the end of the day though, if you use 1 dyno consistantly, the delta's shoud remain the same dyno to dyno, ie. testing each phase on several dynos etc...
Brian
Old Jun 18, 2006 | 02:11 PM
sikpuppy's Avatar
sikpuppy
St. Jude Donor '08
Originally Posted by 99CorvetteFRC
My first dyno pull
That is pretty high both HP and TRQ on a bone stock '99 that is rated at 345 at the flywheel. Nothing done other than filter and remove muffs???
Old Jun 18, 2006 | 03:14 PM
AutoMag's Avatar
AutoMag
Hiya Brian,
Thanks for the compliment!
And yep, on the cars that I watched being dynoed, the ABS light came on, mine included. Would it make any difference if ABS was disabled for a dyno run??
Old Jun 20, 2006 | 11:42 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
ABS light comes on because the computer sees the back tires moving and the fronts are stationary. Doesn't know what to think. No biggie, normal thing.
Old Jun 20, 2006 | 05:16 PM
AutoMag's Avatar
AutoMag
Hmmm, but then won't the computer think that there is a traction issue and brake the rear wheels/close the throttle?
Old Jun 20, 2006 | 07:05 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
Doh! Good point. I'm thinking in terms of the F-body cars which aren't quite as smart as big brother Corvette. However, that issue would be very simply bypassed in the Vette by turning off the active handling. Bye bye TCS. You probably have to for any dyno pulls on the vette's come to think of it.
Old Jun 21, 2006 | 09:38 PM
99CorvetteFRC
Everything was off......It still said it was on? Car must have its own overide ??? but the lights all came on at around 3000 rpm Abs and active handling said was on on the DIC and the lights ??? ABS active Service Active Handling ??? then car shut off at 5000 rpm like hitting rev limiter.
Old Jun 21, 2006 | 10:13 PM
Jay's Z's Avatar
Jay's Z
Dyno pull? Yeeeeaaaaahhhhhsssss. Love it.
LG Pros, x-over, cats, Borla quad Stingers, zip-tie mod, TR-55, Livewires, TB Bypass.
Pull 1 was pre tuning...not too bad.
Pull 2 was after some tweaking.
I'm pretty happy with the results.
Oh yeah...128.8 decibels on the decibel meter.
-Jay
To Dyno pull ???
