what oil filter are you guys using?
Old Jun 20, 2006 | 11:40 AM
scott17201's Avatar
scott17201
Default what oil filter are you guys using?
i need to have my oil changed and was wondering what oil filter i should use.
Old Jun 20, 2006 | 11:47 AM
Milkman2's Avatar
Milkman2
St. Jude Donor '06-'07
Default Baldwin Oil Filters
http://www.adiesel.com/
Baldwin Oil Filters I have been using it on my Tahoe and now the vette.
Old Jun 20, 2006 | 11:49 AM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
K&N, although Mobil has their own filter. I may try it next
Does ExxonMobil make oil filters for use with Mobil 1?
ExxonMobil does offer a very high-quality oil filter that can be used with any motor oil, but it is an especially appropriate companion to Mobil 1. Mobil 1 Extended Performance Oil Filters contain synthetic fibers instead of the typical cellulose filter media. With a 99.2 percent efficiency rating (under SAE J1858 Multi-Pass Efficiency Test), the Mobil 1 filter is much more efficient than a typical oil filter, removing more particles per pass through the filter. In addition, the synthetic fibers in the Mobil 1 filter have less resistance to oil flow, reducing the potential for the filter to restrict the flow of oil to your engine.
Attachment 47594474
Old Jun 20, 2006 | 11:50 AM
TSDuke's Avatar
TSDuke
Amsoil
Old Jun 20, 2006 | 11:59 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I use the AC Delco UPF44 Ultraguard Gold...
Old Jun 20, 2006 | 12:29 PM
KARSC5's Avatar
KARSC5
AC Delco up44 here.
Old Jun 20, 2006 | 12:49 PM
printmanjackson's Avatar
printmanjackson
what's the difference between the UP44 and the UPF44?
Old Jun 20, 2006 | 12:53 PM
BiggieBoy's Avatar
BiggieBoy
Mobil 1 for the last 8 years---no problems so far...
Old Jun 20, 2006 | 12:56 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
buy a case from fredbeans
Old Jun 20, 2006 | 12:57 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Amsoil SDF32 or the new EAO32
Old Jun 20, 2006 | 12:59 PM
rws.1's Avatar
rws.1
I have used the AC Delco UPF44 Ultraguard Gold,K&N, Mobil 1
I just switched to the Mobil 1 extended life and my oil pressure has spiked to 60 psi at idel and 80 psi normal driving...
I do not know if I have a bad filter or if my oil pressor sensor went bad co-incident with the change...
Old Jun 20, 2006 | 01:08 PM
fixvet's Avatar
fixvet
I bought a case of these from Ken Fitchner's Chevy when I bought my '98 a couple of years ago. No problems with oil pressure here.
Old Jun 20, 2006 | 01:13 PM
edensknight's Avatar
edensknight
I have been using K&N oil filters for all my Vettes, Camaro's, Firebirds, and, older American Muscle Cars for well over twenty years.
Old Jun 20, 2006 | 01:52 PM
zguy's Avatar
zguy
same here!
Old Jun 20, 2006 | 02:43 PM
C5 4 ME's Avatar
C5 4 ME
Old Jun 20, 2006 | 02:59 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Mobil1
Old Jun 20, 2006 | 03:00 PM
GrayC5's Avatar
GrayC5
Same here.
To what oil filter are you guys using?
Old Jun 20, 2006 | 03:07 PM
Dave68's Avatar
Dave68
k&N and Baldwin filters flow better than most, according to bobistheoilguy tests. They also filter very well. I've noticed a shorter "time until not tapping" when starting cold - a good measure of flow. The other nice thing about the K&N is its welded-on nut - makes removal a whole lot easier than almost all other filters.
Old Jun 20, 2006 | 03:46 PM
jrose7004's Avatar
jrose7004
I use the K&N!
Old Jun 20, 2006 | 03:53 PM
GR8-LIFE's Avatar
GR8-LIFE
thats good to know. Since i now have a lift, I'll be doing my own oil changes from now on.
