Quick Help Led Tail Light Install
Old Jun 21, 2006 | 12:44 PM
IDM's Avatar
IDM
Default Quick Help Led Tail Light Install
Okay there are 2 Left and 2 Right Lights
1 on each side has a silver metal electrical box on the back and I'm wondering if it matters where I install those as long as I just have one on each side ?
I tested the lights and everything works.
My last question is I am having a hard time getting the old connector to stay on there and seal nicely once I twist it. It doesnt lock into place. Should I just leave it at the spot where it gets the tightest and hope they don't come loose?
Thanks in advance
Old Jun 21, 2006 | 01:27 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Maybe a dab of silicon sealant would work?
Old Jun 21, 2006 | 01:30 PM
IDM's Avatar
IDM
did anyone else have issues installing these?
I am having a hard time with 2 of them fitting because they are hitting some fiberglass tabs that are in the way
Old Jun 21, 2006 | 03:23 PM
jdmvette's Avatar
jdmvette
Night Owl for life
cut the tabs, NBD.
also, mine came with a flasher relay on each light, do yours flash correctly with only 2?
Old Jun 21, 2006 | 03:46 PM
IDM's Avatar
IDM
Originally Posted by jdmvette
cut the tabs, NBD.
What does NBD mean? sorry im an idiot
Thanks for your help. So I really do need to cut the tabs? Do you know exacly what part I need to cut off? Did you have to do that? Only the 2 inside holes had an issue not fitting very well. I was able to push the lights in and then it wouldnt line up on one hole so I slowly twisted it from the back until the hole lined up and then forced the screw in there and tightened it fast before I let go. They seem to line up and be fine now and tight like that I doubt there will be an issue.
LOL about the blinking SHIZIT yes I just checked and they blink retardedly fast. What do I do? Like I said only 2 of the lights had flasher relays That's obviously the problem huh? I got the lights like this brand new
Old Jun 21, 2006 | 04:09 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
No Big Deal
Old Jun 21, 2006 | 10:23 PM
jdmvette's Avatar
jdmvette
Night Owl for life
damn that sucks!!!! yes i had to cut the tabs on mine, it's been reported like that for other installs too.
i don't know what needs to be done about the fast blinking though...i am pretty sure they all need to have that blinker relay.
To Quick Help Led Tail Light Install
