Incompetency Rules the Day
I'm first in-line this morning as the Service department opens it's doors at 7:30. I remind the service tech, "remember, just fix the diff leak, nothing else". "OK, we'll have it back for you today, no problem". No word from the guy all day, so I call at about 5pm, leave a message, and he calls me back a little later.
"Well, hello there Mr. Reed". I hate to tell you that we haven't been able to do any work on the diff leak since it's been sitting over at tech waiting for our electrical guy to do the CLB recall work". My stomach turns, but somehow I'm not surprised. "Uh, don't you remember that I specifically told you guys not to do that work?!" "Oh gosh, we're so sorry! I'll run over to the car right now and leave a note telling them not to do that work!!" Apologies ad infinitum, but alas incompetency seems to rule the day with these guys.
I only took the car in because it's still under warranty. My bad I guess. Sure hope they fix the leak...
It's really hit or miss when it comes to any service organization and how they are run. It's really inexcusable when it's poorly operated, but a well-run service department is worth more than all the fancy advertising in the world.
I tend to do the same thing but technically speaking, we shouldn't have to do that. You normally don't get that kind of thing at Lexus, Mercedes or Inifiniti but then again they have a whole different culture there. having said that, i'm sure there are some horror stories there too.DVS, I hope at least they fix the diff right
I know that not every dealer is good. But, my experience with independent shops is that many of them, too, don't have a clue what they're doing. Some of the guys in my local club take their cars to a local Corvette specialty house but complain about his work all the time. They usually say the guy ain't all that good but they don't trust the dealer. I don't get it.
Anyone in Central Texas work might want to check out Capitol Chevy in South Austin.
When they fixed my rear diff leak, I did have to have a "discussion" about not touching the column lock. I did not want my dash touched since I had already installed a CLB. They insisted that they needed to do the work because it was a safety issue. We ended up agreeing that they would do the latest PCM upgrade, but not touch the dash. I had read on here where on dealer had removed
a CLB, and then tried to charge the person for removing it
I've had it in three times for warranty work, and all positive overall
Good luck dealing with the Stealership!
Chris
They decided that they needed to drive the car (before even hooking it up to the computer to diagnose the problem). Their scientific method of diagnosing what they called a possible intermittent wiring problem was to drive it while listening to the radio to see if the speakers on the passenger side cut in and out.
Lets just say I had to pay to replace the engine (had someone else do the work) and then hire an attorney. Can't go into much more detail right now until the lawsuit runs its course.
So don't be surprised if they do the work that they weren't supposed to just because they felt like it. And always check the mileage on the car when you drop it off...
Good luck!
Chris
1. Listen to the customer. When I have a problem with something (computer, cable, phone, car, whatever...) I detail as much info as I can when I ask for assistance. Invariably they return some cookie-cutter diagnosis instructions, which tell me to do all the things I already told them I did.
2. Set realistic expectations and stick to them. If you say the car will be done at noon, make sure it's done at noon. If you know you won't get to it until 3:00pm, don't say noon. And if you promise to call the customer, call them.
It's sad that we've gotten used to such shoddy service that when a company follows the two simple rules above we wet ourselves with joy.
