Headlight Help
Old Jun 23, 2006 | 07:02 PM
zzdog1's Avatar
zzdog1
Default Headlight Help
I have a 2001. The headlights go up and down fine but yesterday, they started grinding after they were down which lasted about 5 seconds. It sounded as though the motor(s) were still trying to close and that the gears were just grinding as they had nowhere else to go. This sound familiar to anyone? Is it anything I can fix myself?
Old Jun 23, 2006 | 07:11 PM
C7cmnthru's Avatar
C7cmnthru
don't know for sure. sounds like it might be the gears. I think that they are plastic. They do make metal replacements.
Old Jun 23, 2006 | 07:14 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
yep, had mine replaced under warranty. you can get the brass gears through most of the vendors on the site, a fairly straight forward do it yourself project too.
Old Jun 24, 2006 | 12:40 AM
jdmvette's Avatar
jdmvette
Night Owl for life
it's certianly the gears. get a brass set from rodney and you'll be good to go. just be sure to seal that motor back up well, the epoxy didn't hold on mine and i had to take a different approach.
Old Jun 24, 2006 | 09:07 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
however the epoxy held on mine. very easy fix..
Old Jun 24, 2006 | 11:26 AM
The Batman's Avatar
The Batman
Rodney Dickman's new kit includes a metal T-bar that hold the covers down better than glue alone. He gives two, but I think you only need to use one for the passenger side. The orientation of the driver's side motor holds the cover on when it's reinstalled.
http://rodneydickman.com/corvette.html
To Headlight Help
