[Z06] Driverless Z Has Date With Curb
I started to run after it but realized that I could not catch it and stopped and watched and listened to it slowly roll straight into the belgian block curb across the street from the driveway entrance. Ouch!!!
When I got into the car, I saw that the e-brake was still up, but apparently I did not pulled it up far enough.
Fortunately, the damage is mainly isolated to the skid plate assembly which is pretty badly damaged. Because the skid plate mounts the radiator and is pushed back a bit, there is now a gap of about 1 inch between the radiator shroud and the radiator on the left side of the radiator. The radiator seems to be OK so far. I drove the car to work and no leaks and the car drives exactly the same as before.
I have the factory repair manual - the repair does not look too difficult (just time consuming), so I am going to attempt to replace the skid plate assembly myself.
Are there any tricks to this repair?
Good luck on your repairs and be thankful the car did not hit a person.
I am glad to hear that I'm not the only one to pull the handle and leave the car in neutral..... Just last week pulled into a gas station, While I was inside picking up some "Soda", a woman asked "Who's vette is that rolling out towards the street!"
I caught it less than 15 feet from the busy highway! How embarrasing, but as Z06dailydriver says; should only happen ONCE!
The location across the street where my car stopped is the elementary school bus stop. I normally leave for work when the kids are standing there in the morning. Fortunately, school was out for the summer.
After reading all the stories though, when I park it in a lot or the street, I put it in gear (the first time I've done this with any manual vehicle). If you thinkt he vette e-brake is bad, the Jeep's was worse until I adjusted the heck out of it!
-Dave
