Car is BROKEN!!!! :(
Jun 29, 2006 | 01:37 PM
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
While driving into work today.....almost made it all the way in.....and then a SERIOUS vibration starts. I'm wondering what the hell it is......feel it in my shifter first.....I'm thinking maybe my clutch grenaded.....but no, it still seems to be working. Now the vibration is getting worse.....and a loud knocking,,,,,and my gauges are freaking out.....volts going down fast....temp going up fast.....Service Engine Soon on the DIC.......not looking good. Start pulling over.....no power steering.....everything that can go wrong ig going wrong. I'm thinking the worst......engine must be totally blown!
Get pulled over and open the hood.....no oil smoke at least....everything seems normal.....but then I see the belt is off. And then I see the ribbed portion of the harmonic balancer has come off!
I called Sean at OCC.....he says this isn't all that uncommon and he can fix it with a new balancer and 90% of the time there's no other issues......man.....I hope he's right!
Jun 29, 2006 | 01:42 PM
Wow, bad way to start the day. I hope the diagnosis is right on; I like the odds! Best of luck getting your beast on the road again!
Glen
Jun 29, 2006 | 01:45 PM
Jun 29, 2006 | 01:46 PM
CentralTX Events Coordinator
Good luck getting her fixed.
Jun 29, 2006 | 01:47 PM
good luck with the fix!
Jun 29, 2006 | 02:44 PM
St. Jude Donor '06-'08
Jun 29, 2006 | 02:51 PM
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Good luck with the fix! Were you aware of a wobbling pulley issue before this happened?
Chris
Jun 29, 2006 | 03:04 PM
May as well go with an underdrive pulley.
Every time I replace a part, I usually upgrade.
Jun 29, 2006 | 03:08 PM
Quote:
Chris
Had no idea......
Jun 29, 2006 | 03:09 PM
Yep....might as well. I take the same attitude!
Jun 29, 2006 | 03:11 PM
1st step in the right direction.......got it on the flatbed with no damage! Lucked out and found a good tow company!
Jun 29, 2006 | 03:12 PM
UH... wouldn't that be an Undergrade?
Jun 29, 2006 | 03:16 PM
Quote:
Geez............
Jun 29, 2006 | 03:29 PM
Hey Steve, be sure to let us know how you made out. I check my pulley periodically for looseness.....so far so good.
Dennis
Jun 29, 2006 | 04:34 PM
Jun 29, 2006 | 05:08 PM
YIKES.......hope it`s just the balancer!
Jun 29, 2006 | 05:13 PM
St. Jude Donor '06
Hope OCC has you up and running in no time!
Jun 29, 2006 | 05:48 PM
Just out of curiosity, has your harmonic balancer been off before??
Jun 29, 2006 | 06:03 PM
bummer....but thanks for posting the video!
Jun 29, 2006 | 06:20 PM
Glad it wasn't anything worse. Hope you get her fixed and back on the road soon.
