oil change quart amount
Old Jun 29, 2006 | 09:11 PM
beefaronie's Avatar
beefaronie
Default oil change quart amount
Yeah its probaly in the manual and that there are always posts about it, but I am too lazy for any of that. So how many quarts do I put in?
Old Jun 29, 2006 | 09:13 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
With filter, 7 quarts. (Even though the manual says 6.5)
Old Jun 29, 2006 | 09:16 PM
Rhode Warrior's Avatar
Rhode Warrior
That's what I do.
Old Jun 29, 2006 | 09:17 PM
C5naples's Avatar
C5naples
I used 6.5. Here is a pretty good link on oil change;
http://www.spdkilz.com/techtipoil.html
Old Jun 29, 2006 | 09:22 PM
beefaronie's Avatar
beefaronie
Thanks guys. I appreciate you answering, even due to my complete laziness to check the manual.
Old Jun 29, 2006 | 09:33 PM
sorbet70's Avatar
sorbet70
is it nessary to jack up the back?????????
Old Jun 29, 2006 | 09:35 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
7 with a filter...(you lazy bastich)
Old Jun 29, 2006 | 09:46 PM
VetteDawg's Avatar
VetteDawg
If you jack up the front, you gotta jack up the back juuuust a little more than the front.
Old Jun 29, 2006 | 09:52 PM
C5naples's Avatar
C5naples
The oil pan is so flat, jacking up the back is the only way to get all the oil out, or at least that is what they tell me.
Old Jun 29, 2006 | 09:55 PM
sorbet70's Avatar
sorbet70
im wondering how much oil will remain if i just drain the oil without lifting the rear.im not a fan of doing that
thanks
Old Jun 29, 2006 | 09:58 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
thanks
Not enough to worry about...just don't fill it back with 7 quarts...try using 6 1/2 and then keep an eye on the dipstick and if needed , adjust accordingly
Old Jun 29, 2006 | 10:07 PM
sorbet70's Avatar
sorbet70
sounds good
Old Jun 29, 2006 | 11:32 PM
rws.1's Avatar
rws.1
buy 12... you will have more than enough...
Old Jun 29, 2006 | 11:34 PM
jrose7004's Avatar
jrose7004
Takes all 7 qts in mine with filter.
Old Jun 30, 2006 | 12:35 AM
I've always put in 6.5 quarts with the filter change and it has read full. Others report using 7 quarts to reach the full mark. I would start with the 6.5 quarts and add more if necessary.
Old Jun 30, 2006 | 01:41 AM
GrayC5's Avatar
GrayC5
Both the owner's manual and GM Service Manual say approximately 6.5 quarts with filter. However, much will depend on how well the system was drained when removing the old oil.
Old Jun 30, 2006 | 02:22 AM
Cajun99's Avatar
Cajun99
To oil change quart amount
Old Jun 30, 2006 | 06:31 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
1/2 a quart extra wont hurt it
Old Jun 30, 2006 | 07:19 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
I use 7 quarts with a filter change and here's what I use.
Old Jun 30, 2006 | 08:10 AM
Tom/99's Avatar
Tom/99
I put in 6.5 quarts of oil with a new filter. After sitting overnight in the garage, it's right at the full line, on the dip stick.
