Please help
Old Jun 30, 2006 | 07:29 PM
timmydowns's Avatar
timmydowns
1st Gear
Default Please help
I need help. My 1999 vette won't start. I am getting a single click and then nothing. I don't get the click/click/click that I got when the battery is dead. The car won't jump start, just the single click. What are the possiblities. Is this a starter problem or something else? Thanks in advance for your help.
Old Jun 30, 2006 | 07:41 PM
Tigershark3's Avatar
Tigershark3
Sounds like a battery to me. Take it down to Advance or Autozone and have it tested. One of the cells could have shorted out and drained the battery. Good Luck.
Old Jun 30, 2006 | 08:25 PM
Steveo1c5's Avatar
Steveo1c5
Sounds like a realy dead battary, and if it is a jump won't work. What does your volt reading say? Battary Gauge.
Old Jun 30, 2006 | 10:36 PM
landl's Avatar
landl
From: Portland, Oregon . To err is human, to forgive is NOT company policy
Check your cables and connections at the battery.
Old Jul 3, 2006 | 02:07 PM
S/CZ06's Avatar
S/CZ06
Bad starter.
Old Jul 3, 2006 | 03:33 PM
WWK888's Avatar
WWK888
Always start with the obvious, the battery.
Old Jul 3, 2006 | 03:45 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
On my 99 the bolts(posts) the go into the battery were corroated(sp). you can buy just the post at the parts store
Old Jul 3, 2006 | 04:58 PM
Dave1998's Avatar
Dave1998
Have battery tested !
Old Jul 3, 2006 | 05:05 PM
sailohio's Avatar
sailohio
All good ideas. I start with the easiest fix. Check the battery cables to make sure they are tight and not corroded. Then get the battery tested. 95 times out of 100 you got it right. If not, check the starter. You can take jumper cables, hook them to another battery and touch the ends to the started terminals. Be sure it's not in gear. If it doesn't start, you may have a melted fusable link. Have it towed to your favorite dealer. Also, when you hook up the jumper cables be sure the ignition is off and the key is in your pocket. I've seen a guy cross the positive and negative and cause $2500 damage. Good luck. I had the same thing last year. It was the battery.
termike's Avatar
termike
Sounds like a battery to me. The same thing happened with my 02. Tried to jump start it, but it would not start. Forget to turn off the radio and ended up frying it. Had to have it repaired. Put a new battery in and it started, but driving home the air stopped, the windows would not go up or down, everything started shutting down, reduced power, etc. After the radio was repaired, everything was ok. Good luck.
Old Jul 4, 2006 | 08:10 PM
acerider's Avatar
acerider
I had the same problem a few months back w/my '98. It wouldn't start, wouldn't jump off, nothing. Everything visually seemed fine, but as I was removing the battery, one of the terminals twisted right out of the thing, connector and all. It had corrided inside the battery to the point of being virtually disconnected. I cut the connector off the battery cable, put a new one on, replaced the battery, and it fired right up. Good luck!
Old Jul 4, 2006 | 09:01 PM
NJ Vette Guy's Avatar
NJ Vette Guy
If that is the original battery, it's time for a new one....
I had a similar problem with my 2000, it when dead and I had to wait for 10 minutes with jumpers connected to the battery, while the alternator from the other car "charged" my Vette's battery. After it started, I ran the car at idle for 1/2 hour to let the car's alternator charge it.
The next morning I went down to PEP Boys and bought a 880 cold crank Bosch batttery..... For $80, it's one less thing to worry about.....
To Please help
