Fixed fuse problem
Old Jul 1, 2006 | 11:10 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Default Fixed fuse problem
Well, for the third time, I had a fuse blow. Normally blowing a fuse is an annoyance, but not a big problem. Unfortunately, this fuse controlled the break lights, blinkers, active handling, traction control, cruise control, ABS, and hazard lights. One blown fuse really means nothing. The second time I replaced it, I thought something must be wrong. The third time, I just took it straight to the dealer and let them figure it out. It's still under warranty. The next day they called to tell me that they had discovered the problem. About six months ago I had a trailer hitch installed on the car. The shop that installed it failed to properly secure the wiring, and it ended up resting on top of the exhaust system. Once it got hot enough, BOOM goes the fuse. The didn't charge for the repair although technically it was not part of any warrantyable system.
Old Jul 1, 2006 | 11:25 PM
rpm462's Avatar
rpm462
Always nice to hear a positive dealership story...rare as they are!!
Old Jul 1, 2006 | 11:50 PM
jrose7004's Avatar
jrose7004
Trailer hitch? That's a rare sight on a C5!
Old Jul 2, 2006 | 12:13 AM
doje's Avatar
doje
You should come to our Auto-X events. We average 10 cars showing up with little 48" tire trailers. You gotta get the race tires to the event!
Old Jul 2, 2006 | 05:44 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Similar thing happened to a buddy of mine (on his truck). Everytime he hit the brake he blew the fuse. Finally found that some insulation on the wiring to hitch had rubbed through and was causing a short.
Old Jul 2, 2006 | 09:03 AM
Glad you found the source of the problem and that it wasn't anything major. Plus, sounds like a dealership you had do the work.
To Fixed fuse problem
