Clock problems
Old Jul 2, 2006 | 09:30 PM
C7LOU's Avatar
C7LOU
Default Clock problems
Every now & then I get in my '03 Z06 and the time on the clock is off, like it stopped for a few hours or something. I know the battery isn't dead or weak because the car starts fine every time. I reset the clock and it'll be fine for a few days and then do it again. Anyone else ever see this?
Old Jul 3, 2006 | 09:16 PM
wolfmd's Avatar
wolfmd
ttt
Old Jul 3, 2006 | 09:26 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
I've never had that problem. In fact, it's always very accurate. The clock in my Mazda truck runs fast ... maybe 4 or 5 minutes between regular and DST changes.
Old Jul 3, 2006 | 11:50 PM
termike's Avatar
termike
I have had the same problem with my 02. It seems though that it doesn't do it if I don't turn the radio off when I shut the engine off. Sometimes I turn it off and when I restart, I notice that the time is not correct. Go figure.
Old Jul 4, 2006 | 09:44 AM
C7LOU's Avatar
C7LOU
I always turn everything off when I shut the engine down - fan, A/C, radio, etc. Maybe I ought to leave the radio on for a change and see if the clock holds the time?
Old Jul 4, 2006 | 09:59 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
H have a similar problem when I leave the hood open after a ride. It seems like whenever I leave the hood open over night, the next start the clock is wrong.
I have a 6 year old OEM battery, but I have had this problem for 3 years.
Old Jul 4, 2006 | 12:33 PM
JC in XTC5's Avatar
JC in XTC5
Since the clock is internal to the radio, the radio must be either losing power intermittently when the car is off, or the clock circuit in the radio is losing power (going bad?).
If you use the Theftlock feature on your radio, that would confirm whether the radio is losing power since the radio would be locked afterwards and you would have to unlock it. If you don't use this feature, you may be able to rule this possibility out by enabling it.
Old Jul 4, 2006 | 03:50 PM
Bill Dearborn's Avatar
Bill Dearborn
On some of the older Delco radios the clock was on a different electrical circuit than the rest of the radio. Don't know if that is still true but maybe worth checking out.
Bill
Old Jul 4, 2006 | 04:55 PM
JC in XTC5's Avatar
JC in XTC5
Bill
I thought about that as well. But checking the service manual, and there's only one power connection and it's hot at all times (connector C1/circuit 440).
Old Jul 4, 2006 | 04:57 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Would your warranty(if it is still in effect)) cover that problem?
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
No clock issues for me!
Old Jul 4, 2006 | 05:13 PM
C7LOU's Avatar
C7LOU
Yeah, the warranty would cover it provided I trust some of GM's hack mechanics to replace it without screwing it up on me!!!
Old Jul 14, 2006 | 08:19 PM
C7LOU's Avatar
C7LOU
Well, tonight I got in the car and though the clock was correct the feature that adjusts the seat didn't work and all the presets on my radio were gone. Does this sound like maybe the battery is going? My car is an '03 and has the original battery. Any ideas?
Old Jul 15, 2006 | 09:26 AM
C7LOU's Avatar
C7LOU
Ttt
Old Jul 15, 2006 | 09:38 AM
KemahC5's Avatar
KemahC5
I can't imagine letting them start tearing into my dash.......
Old Jul 15, 2006 | 01:14 PM
C7LOU's Avatar
C7LOU
My thoughts exactly! I'm wondering now with the "Easy entry" thing not working and the radio not holding the presets if it's a battery problem and not the clock.....anyone else see this kind of thing?
Old Jul 15, 2006 | 03:29 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
If you do have to take it in and are worried about them tearing into your dash, you can take the console/radio bezel off at home. That way, they just have a couple of screws to remove to take the radio out.
jeff
To Clock problems
