lowering question.....
Old Jul 3, 2006 | 02:49 PM
ttboyvette's Avatar
ttboyvette
Default lowering question.....
I am lowering my car..... I will be cutting the front bushings and lowering the rear as far as I can to look right. I am putting in Bilstien sport shocks. Will I need to change the springs? Why or why not?
Tom
Old Jul 3, 2006 | 06:36 PM
ttboyvette's Avatar
ttboyvette
??? little help.... anyone have any info with this topic?
Old Jul 3, 2006 | 06:44 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
You do not "have" to change the springs.
Have you given any thought to just removing the front bolts?
You will need an alignment...
Peace
Willfulone
__________________
..................Click for
Old Jul 3, 2006 | 07:06 PM
mixermike's Avatar
mixermike
Old Jul 3, 2006 | 07:17 PM
ttboyvette's Avatar
ttboyvette
I would like to get my car as low as possible to get the right look. I just bought 19/20" rims. Is it better to remove the bolts or just cut the 2bushings and leave the 1? If I do remove the front bolt what should I use to protect the spring from rubbing?
Tom
Old Jul 3, 2006 | 07:19 PM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
Old Jul 3, 2006 | 07:29 PM
1 Nasty Z's Avatar
1 Nasty Z
Removed my front bushings and no issues in three years. You will need an alignment in about a week or two after taking them out.
Old Jul 3, 2006 | 09:01 PM
ttboyvette's Avatar
ttboyvette
What did you put under the spring after you removed the bolts???
Old Jul 3, 2006 | 09:54 PM
dajael
Guest
Posts: n/a
Tom
Front bolts are in the trash (although I'm not sure it makes much of a difference compared to just cutting off the bushings which I did as well before yanking them) installed longer rear bolts. I "cut to size" a cheap $1.50 ultra thin rubberish doormat to place between the spring and the A-arm, no issues at all, also swapped out the magnetic ride control shocks for Bilstein Sports. You're going to need a slightly stiffer and shorter shock in the rear if you use longer bolts and slam it or you'll bottom out the stops. No rubbing, slight creak every now and then but nothing bad.
19's & 20's
Old Jul 5, 2006 | 09:13 PM
1 Nasty Z's Avatar
1 Nasty Z
Just use a little synthetic grease between the spring and A-arm. Lets the spring slide bad and forth on the A-arm. I also tried cutting 3/4th's of the bushing off and decided I wanted it lower so I took them out and it made the car about a 1/4" lower with them out.
To lowering question.....
