Went To The Dealer To Inquire About My Diff. Leak , Told Me That Could Be Shaft Seal But Woulnt Know Untill Put On Lift. Warned Me That Could Very Well Be A Crack In The Case,. He Said Not Unheard Of. Told Him That I Have 2 Small Drips On Garage Floor. Thats Why He Thinks It Might Be A Crack In Case.am I Getting Smoke Blown Up My Rear (no Pun ).how The Hell Did I Crack My Diff.? 99 With 45,000 And I Baby The S**t Out Of It. Thanks Guys. Also Automatic.
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
As was said in your other rear thread, GO TO ANOTHER DEALERSHIP. This guy wants your cash badly. I can only imagine what he'll "find" once he takes things apart.
edit- my mistake- the thread that I was taking about was for Bracketman.
Either way, I highly doubt you're diff. is cracked. It's "common" alright.- for guys who do the 1/4 mile with drag radials.
They put mine on the lift and found two bolts loose enough to turn a quarter turn. Put some dye in it and it leaked (seaped) again after an 80 mile trip. New seals are going in under warranty.
I just went thru this with my 98. It was the rear trans extension seal. I had it repaired at a Corvettes only shop for about 50$ more than the dealer wanted and I feel so much more confident in the work.
The way I figure, the dealer works on Vettes because he has to........a corvette shop works on them because they want to!
Total cost- $725.00 2 days in the shop
P.S. that must be a pain to use a capital letter for the first letter of every word in your post?
This "leaking seal" seems to be a very common problem, yet I've never seen a photo of the typical leak location. Does anyone have a photo showing where seal leaks typically occur?
I ask because I also have a leaking rear . I can't pin point where its coming from.
I'd put money on the diff seal leaking
If its not leaked before the original seals are known to be bad. They fit a modified seal to fix it. I'd say challenge his diagnosis
