Code Question
Old Jul 8, 2006 | 10:09 AM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
Default Code Question
Got a check engine light this morning. Code PO 455 HC comes up under the PCM. I cannot find this code on my list so I am loking for help with it. Noted gas cap not fitting tightly. Planing on seeing the dealer Monday for a new cap if nothing else.
Old Jul 8, 2006 | 10:14 AM
DeeGee's Avatar
DeeGee
Had that problem once on the Camaro when I didn't put the gas cap back on properly.
Got this from another site:
DTC P0455
Evaporative Emission System Leak Detected
http://www.digitalcorvettes.com/foru...ad.php?t=50755
Maybe a loose gas cap would cause the leak. That's where I'd start.
Old Jul 8, 2006 | 10:39 AM
OrangeVegaGT
Thanks, so it would seem. Guess there is no harm in driving it like that so long as I check the cap until I can get a replacement.
Old Jul 8, 2006 | 10:45 AM
DeeGee's Avatar
DeeGee
Could you try some type of washer/seal to see if you can get a better fit?
To Code Question
