Need advice
Old Jul 9, 2006 | 12:18 AM
Astronomer's Avatar
Astronomer
Default Need advice
My TPS is reading between 4 and 6 lbs low on all 4 tires compared to multiple tire guages reading the pressure directly. Finally took her into Discount Tire today and they verified all 4 tires at 30. My TPS still says between 24 and 25 depending on the tire.
Is the TPS normally this far off in rainy weather?
Old Jul 9, 2006 | 12:29 AM
GrayC5's Avatar
GrayC5
Your profile says you have a 2005 which is a C6. I would think it should still be under warranty and you might want to have your dealer look at it. Too, the folks over in C6 General may be a better source of info on the C6 TPS rather than C5 General.
Good luck.
Old Jul 9, 2006 | 12:30 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
I always trust my DIC
Peace
Willfulone
__________________
..................Click for
Old Jul 9, 2006 | 12:35 AM
mrgil's Avatar
mrgil
Burnout
Default Tps
They prolly need resetting, Go to your dealer they can do it in about 2 minutes.
mrgil
Old Jul 9, 2006 | 02:26 AM
Astronomer's Avatar
Astronomer
Good luck.
Whoops! Posted in the wrong forum.
Old Jul 9, 2006 | 02:28 AM
Astronomer's Avatar
Astronomer
Peace
Willfulone
Thanks. I did to until today. 5 different guages (including the ones at discount) show my TPS is off.
Thought it just might be a rain thing.
Astronomer's Avatar
Astronomer
mrgil
Will do!
To Need advice
