Oil Change Question
Old Jul 12, 2006 | 01:23 PM
DWALK'00's Avatar
DWALK'00
Default Oil Change Question
I live in Florida where it is nice and hot all year round, and was wondering what oil would be best to use (type and weight). Car is 2000 coupe. I know Mobel 1 5/30 is type called for but have been told with temps down here to use 20/50. Mobel 1 does not make 20/50 so I am loooking for sugestions.
Old Jul 12, 2006 | 01:36 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Mobil 1 does come in a 20W50 weight, I believe it has a red cap vs. the 10W30 has a green cap.
GM recommends 5W30 for fuel conservation and federal requirements. I personally think it's much too thin for hot climates.
I use AMSOIL 5W40 in my Z06.
Old Jul 12, 2006 | 01:52 PM
LoftyC5's Avatar
LoftyC5
Unless you are racing or do all interstate highway driving, Mobil 1 5W-30 is just fine for the Florida weather. If the enjine runs continuously for long periods (4-8 hours or longer) then consider a 40w. I would not use a 50W unless you run at Daytona
Old Jul 12, 2006 | 02:15 PM
DropTheTop's Avatar
DropTheTop
The manual says that 5W-30 is best to use. It also says you may use 10W-30 if it will be 0 deg. F or above. It further says not to use other viscosity oils, such as 20w-50.
Old Jul 12, 2006 | 02:44 PM
rws.1's Avatar
rws.1
only oils that meet GM4718M should be used.
I am not aware of any oil viscosities other than 5W30 and 10W30 that meet this spec.
Dave68's Avatar
Dave68
According to a Mobile 1 technical specialist to whom I spoke, 0W-30, 5W-30, or 0W-40 (provided that they meet GM's spec.) should be the only choices for the vast majority of Corvette owners, whether they live in the Mojave desert or in the coldest regions of Alaska. 10W-30 provides no benefit and actually causes slightly more engine wear at startup.
Dave
Old Jul 12, 2006 | 04:26 PM
cooluhl's Avatar
cooluhl
Old Jul 12, 2006 | 04:59 PM
JC in XTC5's Avatar
JC in XTC5
I lived in SoFlo when I got my car and used 10W-30 only because it's specs were slightly better for that temperature range. 5W and 10W are almost identical anyway, but 10W had a narrower viscosity range which is a slight benefit.
Old Jul 12, 2006 | 11:34 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
In my opinion a 20w50 has too high a viscosity unless you are seeing oil temps over 250F, which I doubt unless you track your car.
For those wishing to stay within the owner's manual recommendation for an oil meeting GM Standard 4718M, these AMSOIL products are labled to meet that standard:
AMSOIL Series 2000 0w30
AMSOIL SAE Synthetic 10w30
AMSOIL SAE Synthetic 5w30
For those willing to forgo the owner's manual recommendation, and who live in a warm weather climate, I feel the AMSOIL Synthetic 5w40 European Motor Oil is a better choice.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jul 13, 2006 | 12:07 AM
vcarr's Avatar
vcarr
Default hot temp
I live where normal summer temps are an average of 100 degrees F, and 5w-30w works great.
Old Jul 13, 2006 | 12:08 AM
I'd recommend what came in the car - Mobil 1 5W30.
Old Jul 13, 2006 | 08:42 AM
Tom/99's Avatar
Tom/99
It's as hot here in Texas is it is in Florida. I use 10W-30 Mobil 1.
Old Jul 13, 2006 | 06:58 PM
bobvet98's Avatar
bobvet98
New Orleans,,, For My October Change I Use 5-30 Then For My April Change I Use 10- 30...
Old Jul 13, 2006 | 07:08 PM
hotwheels57's Avatar
hotwheels57
The synthetic based oils are much better than "old" technology petroleum based oils. Best advice is use what the factory supplied.
Old Jul 14, 2006 | 09:52 AM
DWALK'00's Avatar
DWALK'00
I drive for (1-2 hours at a time) but my oil tem runs about 220-230 F, and the oil reaches this temp within a few minutes of driving. So I guess 10w-30 or 10w-40 would be more were I need to head.
Old Jul 14, 2006 | 10:10 AM
Dave68's Avatar
Dave68
Just to clarify things a bit.....
This is not 1970. The old saying about "the narrower the range, the better" or "stick with straight weight, cause those additives only form sludge eventually" Synthetic oils do NOT need tons of stabilizers to provide protection over a wide temperature range.
It amazes me that so many people think that if they live in a warm climate, they HAVE to run 10 or 20W oils. In MOST cases, a synthetic 0W-30 or 5W-30 oil protect just as well as 10W-30 synthetic oils at high temperatures. Their (0W and 5W oils) added benefit is that they are superior to the 10W and 20W oils in cold temps as well. If you absolutely HAVE to have oil that protects beyond 280F (oil temps), then a 0W-40 synthetic fits the bill. Remember, our engines are not designed to use 20W oils, so stay away from them if your engine is essentially OEM.
Old Jul 14, 2006 | 10:31 AM
davisce's Avatar
davisce
5W-30 is best for your engine . You can use 10W-30 according to your owner's manual. A heavier oil isn't necessary gonna lower the operation temp of your engine .
Maybe you should consider swapping out your stock thermostat for a 160o thermostat and/or change to a bigger radiator. This would do more to lower operating temperature of your engine than a heaver oil .
Just my 2 cents. . . .
Cecil
German-America Corvette Club
Baden-Wurttemberg
Heidelberg, Germany
Hometown: Fort Lauderdale, Florida
Old Jul 14, 2006 | 10:49 AM
DWALK'00's Avatar
DWALK'00
We are not born with it this information and some times the best way to find things out is to ask questions and thats what this forum is for. I am not that up to speed on sythetic oil this is my first car that requires it, thanks for the info now I know.
To Oil Change Question
