Exhaust Problem
Old Jul 12, 2006 | 05:32 PM
Wes Brannon's Avatar
Wes Brannon
Default Exhaust Problem--or maybe not!!
TIA
Make this short--
Car runs great 98 c5 vert
But when I come to a stop and I kind of slam the gas a little to rev it up ---it bogs down like something is clogged up So I start by taking the cat back off (B&B Bullets) still did it. So then I take the cat's out nothing wrong running straight headers --Still does it
Any suggestions
Wes
Old Jul 12, 2006 | 06:04 PM
Z28TOZO6's Avatar
Z28TOZO6
its fuel or ignition related its not a clogged muffler.
Old Jul 12, 2006 | 06:19 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Sounds more like a fuel problem, possibily the fuel pump. What makes you think it's the exhaust?
Also, this is going to sound really stupid but I know someone this happened to, check to make sure the intake is clear (and clean). A friend of mine had a plastic grocery bag sucked up and covered the intake. LOL
Old Jul 12, 2006 | 06:34 PM
Wes Brannon
Because it started at a sound off contest Drove around the block and it was fine (even reving it up while I was moving) but when I pulled back in for the sound off and put it in park and punched it --nope sounded clogged --everyone said it was the cats! Black wing is clear
Old Jul 12, 2006 | 08:33 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Here's what I would check.. in order.
1. the air intake system BEFORE and AFTER the maf. If it is loose, the maf won't sense the correct amount of air coming in and mess up like you've described.
2. Fuel filter. Unlikely to happen 'all at once' but would also cause effects like described.
I HIGHLY doubt it is the cat. They do clog up, but slowly and usually only if you've put TONS of crap in your gas or run LEADED fuel. If you've done one/both, then MAYBE it is getting clogged.
Old Jul 12, 2006 | 09:35 PM
Wes Brannon
Old Jul 14, 2006 | 09:16 PM
Wes Brannon
Got the exhaust system back on and--------------
Took the bridge "off" and coupler--running throttle body only....AND
Still bogs when i come to a stop and floor it very quickly!(neautral of course)
Weird i can be rolling to a stop and punch the pedal and it's fine --it's only when i come to a stop!@#@%#$%
Any other suggestions
TIA
Wes
Old Jul 15, 2006 | 02:44 AM
SLPRC5's Avatar
SLPRC5
How many miles on it. Change the fuel filter..run some Chevron gas.
Old Jul 15, 2006 | 04:17 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Drop your britches and check your DIC, see if you are throwing any codes. It sounds like it's running too rich.... BUT could be a gazillon other things as well.
Old Jul 15, 2006 | 08:18 AM
Wes Brannon
70k
Old Jul 15, 2006 | 08:23 AM
Rhode Warrior's Avatar
Rhode Warrior
Check all your PCV, vacuum lines, etc.
Old Jul 15, 2006 | 08:36 AM
hardtop's Avatar
hardtop
You probably checked the air filter already.
but that sounds like what happen to my car. I had done the "zip tie mod", and had sucked enough water into the filter that it would bog down upon acelleration. ran fine otherwise
Old Jul 15, 2006 | 11:51 AM
Wes Brannon
There is no filter or bridge or anything hooked up!--Thats whats weird
Old Jul 15, 2006 | 11:56 AM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
Good Luck! Sounds like a mystery!
Old Jul 15, 2006 | 10:54 PM
Wes Brannon
No codes
Old Jul 15, 2006 | 11:01 PM
Garrett W's Avatar
Garrett W
Originally Posted by Wes Brannon
TIA
Make this short--
Any suggestions
Wes
Haha this is funny. When I first took my car out with my B&B exhaust installed it did that exact same thing. I was worried that i did something wrong or my car was f***ed up. I just ignored it and it went away after about a month. When I saw this post I thought it was funny becuase I completely forgot about the problem and just remembered it. I really dont know why it does that though.
Old Jul 15, 2006 | 11:14 PM
Wes Brannon
What exactly was your's doing?
This had nothing to do with the cat back as of now. We just started with that 1st
Old Jul 21, 2006 | 08:38 AM
Wes Brannon
Got the car back yesterday!!
Heres the skinny of it!!
Nobody had a clue what the problem was--not on this site or CF. Reese called me yesterday about lunch time and told me he had put several hours in this doing multiple test.And it all boiled down to it be a "traction control" issue... the 97's and 98's are notorious for this he explained. anyway the traction control will need a little work in the future but as of now if I want to enter another sound off I can disable TC and it is fine :greengrin :oyea
I do appreciate MTI's (ATL)promptness and most of all "NO CHARGE"
:oyea
Wes
To Exhaust Problem
