passenger side headlight problem
Jul 14, 2006 | 09:23 PM
St. Jude Donor '06, '13
when i shut the headlights off the motor keeps running on the pass side for 5 seconds after the drivers side stops... any ideas?
Jul 14, 2006 | 09:31 PM
CI 5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08-'09
Send a PM to Not-Mee - he might be able to help you.
Give him a few, he just left to put gas in the car
Jul 14, 2006 | 10:08 PM
From: "when lightning strikes twice, the funerals insane, the funerals insane"
St Jude Donor '14-'15
Quote:
yea, a couple hundred a side unless you do it yourself.
Jul 14, 2006 | 10:11 PM
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Sound like a headlight bumper fell off see file I attached below.
You can order replacements from the dealer.
They call them insulators in the tsb
Jul 15, 2006 | 12:03 AM
thanks guys
Jul 15, 2006 | 12:06 AM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Jul 15, 2006 | 12:35 AM
Your headlamp motor gear is stripped
Run down to the section on headlight gears on this sticky and it explains how to fit the brass headlight gear
http://forums.corvetteforum.com/showthread.php?t=984927
The alternative is to take it into the dealer and have the motor replaced. Big $$$$
Jul 16, 2006 | 03:27 AM
1st Gear
Sounds like the nylon gear is stripped....Replace it with a brass gear.
You will need a little patience, but its an easy fix, plus you will save $$ by doing it yourself.....
Jul 16, 2006 | 01:39 PM
That TSB applies only to the driver's side, and it sounds like just the motor keeps running, not the door popping back up, so I agree this is a gear issue.
Jul 16, 2006 | 01:46 PM
If it's a stripped gear it'll be associated with a grinding noise.
Jul 16, 2006 | 02:21 PM
Cruise-In V Veteran
Quote:
If one of the bumpers pop off either side driver or passenger the motor will continue to run.
The tsb i posted was just for reference and part numbers.
Jul 19, 2006 | 02:08 AM
