Please help.....
Old Jul 20, 2006 | 07:23 PM
JameyTurner's Avatar
JameyTurner
Too Much Fun
Default Please help.....
I have a 2002 Corvette. I have NEVER had any problem out of it..then my AFTERMARKET underdrive pulley separated, so I took it to dealership and they replaced with factory and I sent defective one off...I will NOT say their name UNLESS they refuse to replace a pulley with UNDER 7000 miles on it...since that day in the shop if my car sits still for about 20-30 minutes running the coolent temp will go all the way to 253 degrees and at this point I turn car off (it may keep climbing in temp)...so i replaced thermostat and had coolent flushed and filled.....well, guess what it IS STILL running hot?????
What to check next????
Old Jul 20, 2006 | 07:26 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Is you aftermarket underdrive pulley the same size as the stock on they replaced?
Most aftermarket pulley systems are designed to reduce the rotation of the accy. so that more power can be found...
From the limited info, sound like you have a mis matched set of pulleys now...
Peace
Willfulone
__________________
..................Click for
Old Jul 20, 2006 | 07:28 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
well why would you let them replace it with a stock pulley if you had an aftermarket...?? sounds like you had some other things adjusted to go with the pulley hence you are having issues...
Old Jul 20, 2006 | 08:13 PM
JameyTurner
Too Much Fun
this is my daily driver and I didn't have a choice since the pulley was SEPARATED!!!! the company is suppose to be sending me a replacement....if they don't I will spread their awful customer service all over all boards, especially since only about 7000 miles on pulley!!!! but so far they have been nice....
Old Jul 20, 2006 | 08:17 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
It sounds like the water pump isn't turning! Did the belt get installed properly? Did the adjustment to fit the underdrive pulley cause the belt to be loose over the water pump pulley?
Old Jul 24, 2006 | 04:27 PM
JameyTurner
Too Much Fun
amazing how we overlook the SIMPLE things First!!!! One of my fans was not plugged back up!!! Car runs cool cool cool now! :o)
Old Jul 24, 2006 | 04:34 PM
BadYellowCorvette's Avatar
BadYellowCorvette
Glad you got it figured out man
Old Jul 24, 2006 | 05:07 PM
DallasC5's Avatar
DallasC5
I can help for a small fee--please send cash!!
To Please help.....
