Looking at a C5
Old Jul 24, 2006 | 10:51 PM
joec's Avatar
joec
Default Looking at a C5
So how can one tell if the column bypass issue has been done... The car is a 97 m4 with 15k miles.... The driver seat also rocks about a 1/2 but I saw those posts.. I also know to look at the leaky battery, so if there's anything else to look for please let me know...
thanks,
/joe
Old Jul 24, 2006 | 10:59 PM
81c3's Avatar
81c3
When you shut the car off, pull out the key & see if the wheel locks. If it does....no CLB, if no, then CLB was done. The only other thing would be to check the rear axle shaft seal. The driver side is the one that usually leaks, from what I understand. Good Luck!
Old Jul 24, 2006 | 11:28 PM
diyguy's Avatar
diyguy
If you have been keeping up with the threads, then you should know what to look for. And, if it has minor issue, not that big a deal. Plenty of tech tips to fix it
Old Jul 24, 2006 | 11:29 PM
Steve Theodore's Avatar
Steve Theodore
Also, if it hasn't been done, you should contact GM to see if the car has received the latest service recall for the column lock. Not a true fix, but possibly better than nothing at all (however, the details escape me of what they actually do when they perform the recall fix). Good luck!
Old Jul 24, 2006 | 11:33 PM
ja03c5's Avatar
ja03c5
M4???
PM me the VIN and your e-mail address and I'll tell you a little more about the car through GM VIS.
Old Jul 25, 2006 | 12:35 AM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
`97s either had a four speed automatic A4, or a six speed manual M6.
The last time Corvettes had a four speed manual was 1981.
Old Jul 25, 2006 | 09:22 AM
joec's Avatar
joec
Default yupper..
It was a typo... I must've been thinking about my 65...
Old Jul 25, 2006 | 09:38 AM
rws.1's Avatar
rws.1
Is the digital display for the AC bright?
Does the key fob lock and unlock both doors?
Old Jul 25, 2006 | 09:52 AM
joec's Avatar
joec
Default hmmm
Yes the digital display is bright.. Keyfob battery was dead tho..
To Looking at a C5
