column lock
Old Jul 26, 2006 | 11:50 AM
islandvet's Avatar
islandvet
Default column lock
I have recently purchased a 2003 AE convertable, it is a fantastic machine, nothing wrong with it, but checking through the threads I notice a lot of mention on column lock.Could that also happen on this model ? or had it been rectifid by then. Being the 2nd owner I do not know if there were any recalls on the vehicle or not. Any info would be appreciated.
Old Jul 26, 2006 | 03:10 PM
JoesC5's Avatar
JoesC5
If it's an auto, there is no column lock. If it's a manual, there is a column lock an a recall notice was sent out. Have your Chevy dealer run the VIN to see if the recall has been done on the car(there should be a recall sticker under the hood, if the recall was done, but some dealers don't put the sticker on).
Old Jul 26, 2006 | 03:17 PM
WWK888's Avatar
WWK888
I would seriously reconsider having the recall done. Many people who had no problems before the recall experience error messages afterwards. The dealer may also reprogram your computer to cut the fuel if it perceives a problem (real or not) with the steering lock. This was done on the earlier recall but some techs do it with the new one also which is wrong. It's really a crapshoot with some dealers.
I would just install the CLB if I were you and not do the recall.
Old Jul 26, 2006 | 03:39 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Post the last eight digits of your vin# and I can look in GM's system for it to see what has been done.
Old Jul 26, 2006 | 05:08 PM
islandvet's Avatar
islandvet
last 8 #'s are 35112991 and thank's for the help.....
Old Jul 26, 2006 | 05:36 PM
JC in XTC5's Avatar
JC in XTC5
I agree with your warning to reconsider having GM perform the recall. But I need to correct your statement about the fuel cutoff.
The fuel cutoff has always been part of the CL design - if the BCM detects a locking state mismatch, it will instruct the PCM to cut fuel if the car is accelerated above 2MPH. One of the earlier recalls for the MN6 modified the fuel cutoff programming due to a potential condition that would allow the car to accelerate with the column locked. That recall also spliced a relay into the BCM wiring harness to accomodate the programming change. The recall is no longer valid since GM finally decided to disable the CL on MN6s just like they did on A4s. No current recall should reprogram anything (except for export C5s).
But even this latest recall (4006C) causes more problems than it solves as there have been many posts about cars being disabled by the fuel cutoff because the BCM is sent an incorrect state.
Your options are:
  • If you have an A4 - Nothing is needed. There is no CL in your car since A4s built in 2001+ had the lock removed.
  • If the older recalls have been done and the CL still locks when you pull the key out, you should have GM perform the latest recall which disables the CL all together and installs a Harness K relay to provide the BCM with the correct states. The older recall needs to be reversed in this process by removing the relay that was spliced into the BCM wiring and reflash the car back to original. Then, you should replace the Harness K with the CLB. The GM Harness K solution is faulty and is known to report incorrect states to the BCM, resulting in fuel cutoff. The CLB will keep the BCM happy.
  • If you haven't had any recalls, then the best solution is just install the CLB.
Old Jul 26, 2006 | 06:40 PM
RichieRichZ06
St. Jude Donor '08
Here is the repair history for that car. There is NO history of the column lock problem. BTW, that is a Canadian car that was delivered in BC.
VIN : 1G1YY32GX35112991
VEHICLE INFORMATION
Merchandising Model : 1YY67 -2003 CORVETTE CONVERTIBLE Warranty Start Date : 12/13/2002
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : TOM HARRIS CHEVROLET CADILLAC LTD.
2590 BOWEN ROAD
NANAIMO , BC V9T3L3
(250) 758-2438
Selling Source : 14 - GM OF CANADA
Site Code : 81068
Business Associate Code : 120395
Service Contract : Yes Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/60000 BUMPER TO BUMPER 12/13/2002 15 kilometres 12/13/2005 60015 kilometres
72/160000 SHEET METAL COVERAGE RUST THROUGH 12/13/2002 15 kilometres 12/13/2008 160015 kilometres
96/130000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 12/13/2002 15 kilometres 12/13/2010 130015 kilometres
36/60000 FEDERAL EMISSION 12/13/2002 15 kilometres 12/13/2005 60015 kilometres
0/0 POTENTIAL GRAY MARKET - WARRANTY MAY BE RESTRICTED IN THE US 12/13/2002 15 kilometres 12/13/2002 15 kilometres
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/08/2004 115460 # L2020 - HANGER AND/OR CLAMP, EXHAUST SYSTEM - REPLACE 26225 kilometres
06/08/2004 115460 # Z7901 - 1-DAY COURTESY TRANSPORTATION 26225 kilometres
11/07/2002 A12991 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 kilometres
© 1998-2005 General Motors Corporation. All Rights Reserved.
Old Jul 26, 2006 | 07:58 PM
maxfli's5's Avatar
maxfli's5
i can only say have the bye pass kit put in the car !! my car which is an automatic had the recall done !!drop me twice, once was on the way to have the the bye pass kit installed in the car had to load the car on the trailer. but once you install the kit it also clears the the code i was amazed !!! my brothers car which is a mn6 car had the recall done put him down and he paid over $700 dollars to get it going again within a month he gets the pull key wait 10 sec code on the DIC don't be fooled by this. have the recall done , get the coloumn lock bye pass kit and be rid of this night mare
Old Jul 26, 2006 | 08:02 PM
WWK888's Avatar
WWK888
Why get the recall, just install the CLB.
Old Jul 26, 2006 | 08:04 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Easy to do and you know it got done.
Old Jul 26, 2006 | 09:06 PM
If you have the manual tranny, install the column lock bypass. You won't have to worry about it locking with that installed.
Old Jul 26, 2006 | 09:08 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
http://forums.corvetteforum.com/show....php?t=1455432
Old Jul 26, 2006 | 10:15 PM
islandvet's Avatar
islandvet
Hi RichierichZ06.
Thanks for looking that up for me, not good on computors yet, still flailing about.Looks like the vette is o.k., at least he didn't appear to have problems with it. I bought the extended warranty so am not worried much, but would not want to be stuck on the road waiting for a tow truck. Guess I better go to the dealer and ask him to check it out for me. JoesC5 in an earlier reply stated that if it was an automatic ( which it is ) then it does not have a column lock???????
Old Jul 26, 2006 | 10:18 PM
jrose7004's Avatar
jrose7004
I have an automatic and the column locked! The car was flatbedded to the dealer and they did the recall one day after I got the recall notice.
Old Jul 26, 2006 | 10:21 PM
WWK888's Avatar
WWK888
Hi RichierichZ06.
Dude...you have a 2003 Auto which means you have no column lock. All you had to do is turn the wheel with the ignition off to see if it was locked. If it is then you really have a problem...
Old Jul 26, 2006 | 10:23 PM
WWK888's Avatar
WWK888
That is because you have a 98 auto.
Old Jul 26, 2006 | 11:11 PM
islandvet's Avatar
islandvet
Hello WWK888,
yOU are right, I just went out to try the steering and no column lock,
went through the owners manual again and found it on pg.3-55,
Service column lock ( Manual transmission only ) sorry for the run around, but I had to check it out. I've read that manual half a dozen times, but I didn't pick up on it.
Old Jul 26, 2006 | 11:33 PM
WWK888's Avatar
WWK888
Now you can put your mind at ease...enjoy the car!
To column lock
