Arrgghh!
Jul 27, 2006 | 06:13 PM
Arrgghh!
This is 2 days in a row now that my car has got in the red. It is about 113 degrees here for a few days now, but I let it cool down & refilled it, then it wanted to boil over again today.
Anybody else have similar problems in high heat, also, my car is black; I'm sure that doesn't help....
Jul 27, 2006 | 06:16 PM
Are you sure your fans are coming on when they should? We had 110f here in the bay area last Saturday and the cars operating range was about normal.
BTW it started cooling down big time today - I know we're near the coast, but I think the trend is in the right direction.
I'd check your themostat to make sure it' opening all the way.
are you talking about water temp in your radiator?
if you are getting in the red
you have a problem.... its not the outside heat thats doing that, its your fans not kickin in..... make sure that fans work
and what was you DIC showing for water temp?
Jul 27, 2006 | 06:19 PM
253 was the highest I saw it get.
Jul 27, 2006 | 06:20 PM
I'll check the fans, caus it's never got hot like this before.
No matter how hot it gets outside.....it's been over 100 here for about a month.
Jul 27, 2006 | 06:21 PM
I regularly run in 110+. Once the fans kick in the temperatures come down. May be a problem there?
Jul 27, 2006 | 06:22 PM
Good deal, I noticed the weather is actually supposed to be just under 100 here for the next few days. It'll be a decent break.
Jul 27, 2006 | 06:24 PM
We're not used to this heat out this way. We crawl inside and hug the air conditioner. But it was about 80 today
Jul 27, 2006 | 06:32 PM
'm running a 160 with electric water pump. It gets freeking hot in Vega$. My temps stay at about 185 to 190 when it 115 outside.
From another thread about 160f thermostats.
Jul 27, 2006 | 06:34 PM
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
I would first look under the front of the Vette - up at the radiator.
Many, many, many times there is debris in that area, and it will affect your temp.
Jul 27, 2006 | 06:44 PM
Just started it up in my garage, got it as hot as it would get.....temp read 246, which is just how it used to run, not in the red.....
Also, fans were kicking on normally, I also turned the air cond. off for a while to see if that made a diff. & it didn't.
Weird?
Jul 27, 2006 | 06:45 PM
Just checked it, all clear.
Jul 27, 2006 | 07:22 PM
What temp did the fans kick on?
Anyone know the correct temperature? I believe this is a parameter that can be re-programmed.
There's also a chance your thermostat isn't opening all the way. Sure sounds like something's amiss.
Good luck
Jul 27, 2006 | 07:35 PM
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Check waaaaaaay up under the front at the top of the radiator. You have to find a way to get your head under the front end because you can't see all the radiator unless you do it. I had to jack the front end up to crawl under it because it's lowered, (and my gourd is too big to fit under the front bumper). Anyway, mine was acting the same way and I found a Wal-mart bag (and a few leaves) stuck where I couldn't see it. It only takes a very small restriction to overheat a C5. Got the crap off the radiator...no more overheating.
Jul 27, 2006 | 07:36 PM
If I have the air cond. off, my fans kick in at 225f. Ive never seen higher than 228
Jul 27, 2006 | 07:50 PM
CI 6-7-8-9 Veteran
Jul 27, 2006 | 09:12 PM
Might want to check and see if you have some trapped air in the cooling system!
Chuck
Jul 27, 2006 | 09:13 PM
Cruise-In VIII Veteran
St. Jude Donor '07
That would be the first place I would check.
Jul 27, 2006 | 09:52 PM
Quote:
Chuck
Is it similar to the LT1 where you unscrew a brass fitting untill air comes out, then tighten after coolant spews?
