Slow Windows - Why?
OK, so it takes longer you say - so what?
Well, I run the Window Valet for putting the windows down AND up. The nice thing about putting them up is stopping them just before full close for venting in hot weather (and we all got hot weather now!). But with the slower window, stopping for vent leaves a larger gap on one side than the other.
So again, can it be - or does it need to be - lubed? Or is there another calibration or adjustment I'm missing?
If the fits similar it could be a number of things. The scissor shackles need a good lubrication or they run slow. That's where I'd start. There's a buffer which holds the window glass tight against the weather seal. If its over tight it can slow the window down but normally only near the top.
The bad news is it could be the motor on the way out. The motors slowly give up the ghost and go slow before they quit. Basically they can't cope with the effort.
Maybe someone who has done work on the Vette will chime up.
Hope this helps.
