[Z06] Couldn't find a weight reduction thread?
All that being said, the usual weight loss stuff still applies:
Lightweight battery (up to 30 pounds)
Seats (not sure how much, but certainly possible)
Front brakes (StopTech or similar - 8 pounds per side iirc)
Hood (Z16 hood weighs about 10 pounds less)
I'm definitely not an expert on C5Z weight reduction at this point though, so that is about all I can say on the matter.
This is what I was thinking
Battery 30lbs
Seats 25-35lbs
Door bars 20-30lbs
Front and rear bumper support 60lbs
A/C 30-40lbs
Carpet 20lbs
Then unsprung weight such as
Flywheel 15lbs
Wheels?
Brakes? Could add weight if its a big brake kit
Then addition of Roll Bar 60lbs
So far the reduction in weight would be around 215lbs. Add another 60lbs of roll bars and that brings the reduction to 155lbs. Giving a C5 Z06 weighs around 3100lbs that would bring the car down to 2950lbs or so. Is it possible to bring the Z06 down to 2750lbs or so?
Steve T.
If I remember correctly, if a forum member on 3si got his car down to
34-3500lbs or so, that was a big deal! lol Not sure about Supraforums... you guys arent too much lighter tho.
I remember reading about the F-40.. that thing weighs like 2400lbs.. TT-small V8.. can you imagine? congrats on getting your Z!
Go lighter to go faster!
Take out the stock seats and put in race seats, 30-40 lbs each
take out speakers and stereo, 20 lbs
light weight battery
remove ac condesor.
Light weight wheels, 17" wheels are lighter and faster.
Light weight brake rotors, Check rules you may have to run stock equipment in many cases.
BBKs add weight.
adding a roll cage is +200 lbs
most race series have minium wieghts too, with drive and fuel after the race. I think T1 is 3200 lbs min.
Ranger
Ranger
Im not going to run in T1 class. I just want to make the car the fastest possible.
His weight reduction thread took a lot of research for J-Rod to assemble. So a tip of the hat to him is in order.
Ranger
