Another Lowering ?
Penetrating Oil.........You can find it just about any hardware store or auto store that sells WD.
Back in the day, wet ignition wires from condensation and maye even road spray, would kill your spark. The guy who invented WD40 was looking for a spray that could be applied on wet spark plug wires and get you going again, quickly. The name is a natural, he tried 39 blends of chemicals before finding the one that worked as a great Water Displacer....the 40th try. Hence WD for Water Displacer, and 40 to 40th try. I guess you have to old to know this, it was common knowledge in every workshop when I was a kid in the 50s
My dad would scream bloody fits about using the right stuff for the job,and always had a can of WD40 AND a can of Penetrating Oil around.
We use a special blend of penetrating oil made by KANO Laboratories called Kroil. You can't buy it in stores, but you can from their website. However, just to make those front adjuster screws easier to turn, any brand from the auto parts store wil work just fine.
Hi Jennifer -
WD-40 just fine for simple lubricating AND penetrating needs.
I have been using it on rusty bolts for 30 years and it works very well.
It will also work very well for the simple need of providing some lubrication on the rubber pads on the front ride-level adjusters.
I also have PB-Blaster and CRC for penetrating oil needs (PB works better than WD-40 IMO).
The makers of WD-40 seems to think it works as a lubricant, and penetrating solvent....
http://www.wd40.com/Brands/wd40_product_info.html
best regards -
mqqn
Mark
