Another Lowering ?
Old Aug 1, 2006 | 09:54 AM
waupachino's Avatar
waupachino
Default Another Lowering ?
Ok, before the flaming starts, I have read the tech tips on the Lowering procedure. What I want to do is only lower the car a little. About 1/2 an inch. The roads I drive on in STL are way to rough to be too low. What is the best way to lower the car only a little and not all the way on stock bolts. I was thinking starting off with maybe two or three full turns on each. Would this be correct thinking?
Old Aug 1, 2006 | 10:02 AM
sailohio's Avatar
sailohio
We call it "lowering on the bolts". In each corner of the car, there is a stud through the spring with a nut on top. There should be around 1" to 3/4 " of thread sticking out the top. What you do is back off the thread until there is only about 3 threads showing on top of the nut. This will lower the car around an inch. Have more threads showing if you want to lower it less. It is very easy to do. See this thread. https://www.corvetteforum.com/techti...D=27&TopicID=1
Old Aug 1, 2006 | 10:16 AM
Y2K Corvette's Avatar
Y2K Corvette
I may be wrong, but the front bolts will have a whole lot more then 3 threads showing if your lowering it, i backed my bolts out all the way in front and it dropped around 3/4"
Old Aug 1, 2006 | 10:26 AM
dndrsn's Avatar
dndrsn
I measured mine from the floor to the fenderwells before I lowered it as far as it would go on stock bolts. After driving around some I measured again and it had fell 7/8" in the front and 1" in the rear. I then raised the rear up enough to give it some rake.
Old Aug 1, 2006 | 11:35 AM
waupachino's Avatar
waupachino
I have read the threads on how to do this, my main question is if I am correct in thinking that if I only go say three full turns or so it will not lower the car as much? I don't want the car to be slammed, just a little lower like about 1/2 inch. Thanks for the replies.
Old Aug 1, 2006 | 05:48 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Mine has the Z51 and if I remember correct, every round is about 1/16" move.
Old Aug 1, 2006 | 07:56 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
I did five full turns on each corner and it lowered mine about one inch. Just gauge it from there. Try two and a half turns and drive it a while. It will take some time for the springs to settle. I've got a little less than a half inch rake from rear to front so I'm leaving mine alone.
Old Aug 1, 2006 | 07:58 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
If you drop it as far as it'll go on the bolts, you'll only get about 3/4 inch anyway...and the rear will drop a hair more than the front on the bolts. But different cars may react somewhat differently.
I'd drop it all the way and then take a look at it. If unacceptable, then turn each bolt an equal amount.
Oh, BTW, don't measure it as soon as you take it off the jacks. It'll be in "4x4" mode. You have to drive it around the block a couple of times for it to settle down.
Old Aug 1, 2006 | 08:47 PM
MY1STPEWTER's Avatar
MY1STPEWTER
And if you have the Z51 option it'll be less than the standard. Don't worry, you won't be anywhere near slammed by lowering on stock bolts. I've got the Z51 and could barely tell it was lowered on stock bolts. I then cut 2/3 of the front bushing and put longer bolts in the rear, looked better then. Like JACKALOPE says, go all the way and if you don't like it, raise it back up. 3/4 of an inch isn't much.
Old Aug 2, 2006 | 10:54 AM
waupachino's Avatar
waupachino
Thanks for all the input. I have the base suspension, I think I am going to start off with 3 full turns on each and see what that gives me. I already drag the air dam at times now, and really don't want to get any worse. I love the way they look lower, but the roads around where I live in STL are just way to rough to even think about going all the way down. The thought of bottoming out a rocker panel is just plain sickening.
Old Aug 2, 2006 | 11:09 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi waupachino -
Your thinking is correct - I think it will be more like 6 turns to go half way.
If your car is a Z51 or Z06, it does not (in my experience) lower down as much due to the springs and shocks being stronger (I think).
As far as hearing the front rubber air deflector scrape - i guess you either do not lower it, or lower it and turn up the radio.
Seriously, the air dam is a very cheap, easily replaceable, and in my opinion emminently disposable item and scraping it on the bumps (and roadkills ) is part of the lowering program.
I have both of my C5's lowered to the stock limits, along with almost all of my local friends whom I could talk into it) and have not issues.
I live in Peoria, and dare say that the roads here are as bad or worse than St. Louis roads.
If you are even in the area, pm me - I have a lift and you are welcome to come on up.
Go for it!
best regards -
mqqn
Old Aug 2, 2006 | 12:11 PM
waupachino's Avatar
waupachino
Hey mqqn your about 178 miles from me, but I do appreciate the offer. Thank you and Thanks for the input. This is probably going to be my weekend project this week in the drive way.
Old Aug 2, 2006 | 12:21 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi wupachino -
That's only a 2.5 hour drive lol.
I'll be in the St. Louis this weekend (Cards game Saturday).
best regards -
mqqn
Old Aug 2, 2006 | 01:22 PM
dndrsn's Avatar
dndrsn
I think the fronts are too aggravating to do to be adjusting them incrementally, you are only going to get 3/4" or so by turning the bolts all the way up. The rears on the other hand are easy to do if you want to readjust them to match the front or give it a little rake.
If you are driving down the highway and run over a tractor trailer retread or Rocky Raccoon, 3/4 of an inch will not make much of a difference.
Where you live doesn't make much of a difference either I don't think. I live in Florida, yes it is flat down here but, the speed bumps are just as high down here as anywhere else and also the homes down here have drainage swales in the driveways which cause the front to scrape.
Parking space stops will hammer the bottom real good until you learn to stop when you think you are 5ft. away from them, and they are everywhere.
Here is a pic of mine lowered on stock bolts. I placed a D-cell battery under the air dam to give you an idea for ground clearance.
Old Aug 2, 2006 | 01:37 PM
Vega$Vette's Avatar
Vega$Vette
Each full turn will give you approx. 1/6" drop so with 3 to start you are not going to see much difference. 1/4" - 3/16". It will vary that much just with just more or less fuel load. I'd start with 6 turns to save you crawling under the care again.
Old Aug 2, 2006 | 02:45 PM
waupachino's Avatar
waupachino
Originally Posted by mqqn
Hi wupachino -
best regards -
mqqn
Go Cards, you are alos lucky the 100 Heat is supposed to clear out by the weekend and the high on Saturday is going to be 92. I have a friend going to the game tonight and with a high in the 100's I don't think I would want to be there.
Old Aug 2, 2006 | 04:00 PM
Vega$Vette's Avatar
Vega$Vette
Lowering will produce more bolt thread showing on the front and less bolt thread showing on the rear. The bolts are called "ride height adjustment bolts" Simply stated. If you want to lower you car as far as possible without changing rear bolts or cutting front bushings you would turn the front bolts counterclockwise until it stopped and you would turn the nuts on the rear bolts counterclockwise until you had only 1 or threads showing below the C-clip that is attached to the top of the bolt.
To Another Lowering ?
Old Aug 2, 2006 | 04:19 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
H8i waupa -
No kidding!
I was hoping it would calm down a bit before Saturday.....
BTW - make sure you have a 10mm six point closed end wrench for the front bolts - and spray some wd-40 on them , and relieve the pressure from the spring - that'll make it much easier to turn the bolts.
best regards -
mqqn
Old Aug 2, 2006 | 06:02 PM
Vega$Vette's Avatar
Vega$Vette
H8i waupa -
No kidding!
best regards -
mqqn
If you have a ratcheting box end 10mm perfect. Definitely relieve spring pressure on the front and WD40
Old Aug 2, 2006 | 10:30 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Hi waupachino -
Go for it!
best regards -
mqqn
why can't you live in the houston area???
