Fuel Sending Unit?
Old Aug 2, 2006 | 09:00 AM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
Default Fuel Sending Unit?
Hey guys
i am having this problem with my fuel guage on the dash. It reads 1/2 empty on a full tank. It is constanty wavering and i get the "Low Fuel" and "Reserve Fuel" reading on the DIC. So even if i have a full tank, it only reads half full...
What is wrong with my car? Is it the fuel sending unit? Any ideas? Anyone? Im desperate here!!! I need to get this fixed asap!!!
Any and all help is very much appreciated! Thanks.
Aj
Old Aug 2, 2006 | 09:16 AM
PVHolgado's Avatar
PVHolgado
Go get some "Techtron" fuel additive- dump a bottle in each of the next two tank fulls - if you are lucky it will clear up the problem-- if not you may need a new sending unit- Search the threads here - very common problem- good luck-
Old Aug 2, 2006 | 09:46 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Hey Aj, What brand of gas you using? I've been using SA and so far no problems.
Old Aug 2, 2006 | 11:05 AM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
PV: i have tried the Chevron with Techron 2 times now...no luck unfortunately...
PTDrummer: I use main Holiday or Citgo... 92 octane or highest grade available... is there a gas station i shouldn't use???
Thanks guys!
Aj
Old Aug 2, 2006 | 11:38 AM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
I've been using Super America (also the 92 octane) for over 3 years and haven't had any probs. If you've already tried the techron though you my be among those that need to replace the sensors
Old Aug 2, 2006 | 01:24 PM
Grzldvt's Avatar
Grzldvt
Been down this road myself, with multiple cleaners changing brands of gas, and to no avail. If you are pre-2000(?), I beleive the only fix is sensor replacement, after 2000, there is a software fix.
This is a common problem and a search will probably bring up a ton of posts.
Old Aug 2, 2006 | 01:37 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
I've read here that GM has a new "Magic Crap" that you add to your tank to "Fix" this problem. OK, WHATEVER.
To Fuel Sending Unit?
