Radiator cap?
Old Aug 4, 2006 | 08:02 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Radiator cap?
Does the C5 have a radiator cap under the shroud or is the only place to put in water... the reservoir? I want to put some "water wetter" directly into the radiator.
Old Aug 4, 2006 | 12:11 PM
hotwheels57's Avatar
hotwheels57
The plastic cap on the coolant reservoir if the fill point.
Old Aug 4, 2006 | 01:40 PM
Hvymtlc5's Avatar
Hvymtlc5
thanks - guess I'll just drain some coolant from the radiator and then pour the water wetter through the reservoir hose to make sure it gets back in the radiator
Old Aug 4, 2006 | 01:45 PM
hotwheels57
...as soon as your start the car and the thermostat opens, the water pump will circulate the WATER WETTER through the entire system. Doing it your way might introduce air into the system resulting in fluctuating coolant temperatures and other issues to the oem coolant.
To Radiator cap?
