Be Careful! Jacking Pad Failure....
Old Aug 6, 2006 | 06:33 PM
Rogue Leader's Avatar
Rogue Leader
St. Jude Donor '08
Default Be Careful! Jacking Pad Failure....
I posted this in C5 Tech too but just in case you guys dont see there I dont want anyone to get hurt. I had FOUR (4) jacking pads from Corvette Accessories Limited fail on me this weekend. Two of them failed more spectacularly than the otehr two (as in the car could have fallen off the jack). I was not under the car when this happened I was just changing my wheels for my race wheels. These pucks were less than 6 months old and used maybe 6 times in total. I just ordered Billett ones from Elite Engineering, and I would reccomend anyone who uses pucks to consider those, I got away lucky this time, I dont want to hear about anyone less fortunate.
Old Aug 6, 2006 | 06:35 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
How did they fail?
Old Aug 6, 2006 | 06:36 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Originally Posted by ptdrummer54
How did they fail?
I made my own using 2 solid bar and eye bolts
Old Aug 6, 2006 | 06:37 PM
Rogue Leader
St. Jude Donor '08
How did they fail?
The one on the left was the worst, it basically split in half.
the one on the right was similar to how all 3 ended up, they basically cored themselves and the outsides peeled off, the middle is also cracked and probably would have come apart had it sat more.
Old Aug 6, 2006 | 06:39 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
I'd be interested to hear what CAU has to say about this...
Old Aug 6, 2006 | 06:40 PM
Zilla's Avatar
Zilla
Old Aug 6, 2006 | 07:09 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Wow,
that's scary. Glad you were not under the car. I have 4 hockey pucks with I bolts. I haven't used them all at the same time, but they seem like they should hold up.
Old Aug 6, 2006 | 07:11 PM
Rogue Leader
St. Jude Donor '08
Originally Posted by Cozmo
Wow,
I actually wasnt using all of them at the same time. The first one cracked in half yesterday when i was doing my drivers side wheels. I went on with the second one to the passenger side and I was like NFW 2 would fail... sure enough it did.
But, those two were sitting in my front hall in 100+ degree heat the past few weeks. So I went to my basement and grabbed the other two that I had which have been sitting at basically constant room temprature, and I doubt Ive even used them more than once. Those two also began to fail similarly to the one on the right altho much much less severely.
Old Aug 6, 2006 | 07:23 PM
Fast98's Avatar
Fast98
Wow thats crazy
Old Aug 6, 2006 | 07:27 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
I've got the Elite Engineering pucks and they are awesome! I did use some Rhino ramps for a bit until they cracked while doing an oil change on the Impala, bent the lower radiator support.
Elite makes awesome products and awesome service.
Old Aug 6, 2006 | 08:43 PM
SilverSurfer66's Avatar
SilverSurfer66
Originally Posted by Fast98
Wow thats crazy
I have four on the way.
anyone else have this problem?????
Old Aug 6, 2006 | 08:45 PM
I have the same jacking pucks from CAU as you do - they are probably four years old. No problems yet, but your post makes me .
Please keep us posted on what, if anything, CAU says about this if you call them.
Old Aug 6, 2006 | 08:48 PM
Oldvetter's Avatar
Oldvetter
I use solid aluminum ones, I never liked the flex of the plastic/rubber ones.
Old Aug 6, 2006 | 08:59 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Jay-sus!
And here all this time I thought I'd just wasted money on those billet ones of mine.
Old Aug 6, 2006 | 09:30 PM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
i to have solid aluminum ones, didn't know there were any other type.
good to hear you weren't hurt.
Old Aug 6, 2006 | 09:43 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
I agree, I use solid aluminum pucks.
Old Aug 6, 2006 | 09:45 PM
Bingo Fuel's Avatar
Bingo Fuel
Let Me Bignofi That For U
St. Jude Donor '15, '17
I have the billets also, but you sure wouldn't expect to
see those fail like that! Glad you were safe
To Be Careful! Jacking Pad Failure....
Old Aug 6, 2006 | 10:16 PM
Rogue Leader
St. Jude Donor '08
I just looked over the included instruction sheet and there arent any instructions saying that you could use or not use a floor jack on the pucks. It actually only describes their use under a lift or as supports under a pair of jack stands. Due to the cup shape of the floor jack that maybe theoretically would prevent the issue I had with the 3 of them... however the one that just straight out split in half it would not have prevented. Im glad I had the cup shaped floor jack holiding it up like that as if I had it on a jackstand when it split like that at best I may have damaged my rocker, at worst my car would have fallen on the front suspension or rolled into traffic.... preferably not removing a limb of mine in the process....
I guess I will e-mail the pic to them and just tell them about the issue. I am not going to make a big issue of it, its only 50 bucks, I am more concerned about keeping my friends here from getting a face full of oil pan the next time they are under the car.
Old Aug 7, 2006 | 12:54 AM
JNS's Avatar
JNS
St. Jude Donor '06-'09
Now THIS is really scary. Has anybody else had their Rhino Ramps fail like this?
Jeff
Old Aug 7, 2006 | 01:06 AM
Miguels's Avatar
Miguels
ARE they made from plastic or rubber?
just curious
