CLB install is causing the "Pull Key" error
Old Aug 6, 2006 | 09:36 PM
jrprich's Avatar
jrprich
Default CLB install is causing the "Pull Key" error
OK, I am officially confused
My 99 had not had any steering colum issues since I bought it four months ago. But after reading all the horror stories on the Forum I bought a CLB from CoH and installed it as directed.
At first start up it died and threw the "Pull Key" error. I did so and all seemed well. A week later it happened again. So it seems the CLB is triggering these errors that I had not seen before.
Should I pull the CLB ?
Dealer repair history follows:
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
08/19/2005 420673 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 23316 miles
08/19/2005 420673 # R4485 - BATTERY, REMOTE DOOR/REAR COMPARTMENT LOCK TRANSMITTER - R 23316 miles
10/23/2001 330724 # V0743 - ECL RELAY HARNESS REPLACE 8570 miles
11/29/2000 311045 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 5988 miles
02/16/1999 270306 # N4180 - CLUSTER ASSEMBLY, INSTRUMENT PANEL - R&R OR REPLACE 316 miles
02/16/1999 270306 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 316 miles
01/07/1999 267923 # N2700 - SWITCH, STOP LAMP - ADJUST 294 miles
01/07/1999 267923 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 294 miles
12/02/1998 019693 # J5582 - MODULE, ELECTRONIC THROTTLE CONTROL - REPLACE 11 miles
Old Aug 6, 2006 | 10:07 PM
Dave1998's Avatar
Dave1998
This is not so unusual. I installed my CLB 2 years ago, and I got the message today. I turned off engine waited 10 seconds and no message. this is about the 10th time. I am not worried about this because it will always go away after the wait and you will never walk home .
Old Aug 6, 2006 | 10:50 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
no worries....Sounds like cl module lost sync with the bcm
1. turn car on on position. (do not start)
2. open fuse panel in passenger side floor board.
3. pull fuse #23 (BCM) wait 10 sec
4. re-install fuse
5. pull key out for 10 sec
6. restart car.
Old Aug 6, 2006 | 11:03 PM
TonyC5's Avatar
TonyC5
4. re-install fuse
6. restart car.
Great advice, will try it myself... Thanks for the good info!!!
To CLB install is causing the "Pull Key" error
