Tire Pressure
Old Aug 7, 2006 | 10:26 PM
Mason357's Avatar
Mason357
Default Tire Pressure
What do you guys recommend for after market tire pressure on a C5 Vette
Old Aug 7, 2006 | 11:06 PM
thisMSGgood4me's Avatar
thisMSGgood4me
The pressure recommended on the sticker on the side of the door: 30 psi cold.
Old Aug 7, 2006 | 11:09 PM
rws.1's Avatar
rws.1
any tires 30 psi
Old Aug 7, 2006 | 11:17 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Old Aug 7, 2006 | 11:19 PM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
Yeppers... 30 pounds
Old Aug 7, 2006 | 11:21 PM
03CARISMA's Avatar
03CARISMA
Old Aug 8, 2006 | 12:04 AM
RUBYREDVET's Avatar
RUBYREDVET
Does the 30 lbs also apply to Z06 tires and rims?
Old Aug 8, 2006 | 01:12 AM
thisMSGgood4me
What does the sticker on the side of the door say?
Old Aug 8, 2006 | 10:20 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
There have been a lot of threads on this topic, you might consider trying a search.....
http://forums.corvetteforum.com/show...=tire+pressure
I'm sure there are more in the archives.....
Old Aug 8, 2006 | 10:53 AM
RUBYREDVET's Avatar
RUBYREDVET
I've got an '03 MN6 (non Z06) with chrome factory Z06 rims and tires. I was wondering if the Z06 sticker says 30 lbs or some other number.
Old Aug 8, 2006 | 11:07 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
The Z06 sticker says 30psi cold.
Old Aug 8, 2006 | 11:16 AM
blacksedan87
Correct tire pressure is not something that would be determined by the tire manufacturer, other than to state the maximuim recommended air pressure and maximum weight. The correct tire pressure would be stated by the vehicle manufacturer, as the vehicle manufacturer performs an analysis as to what tire pressure offers the best ride, handling, braking and tire wear characteristics.
So in answer to your question - regardless of what tire and wheel combination that you chose to run, the vehicle's stated recommended tire pressure is the guideline that you should follow.
That said - remember that tire pressures fluctuate based on the heat absorbed from the road surface as well as the friction that is created by the rolling tire. So summer ambient temperatures, plus road surface temperatures will increase actual tire air pressure more that it will on cold weather.
Personally - I like to run my tires 31-32 lbs year around. So in the summer, I run my cold TP around 27 lbs, and in the winter I run them around 29 lbs.
If you have ever watched a NASCAR race - the crew chiefs have someone devoted to measuring the tire pressure and tire temperature, because handling characteristics change with fluctuating pressures and temperatures. Races can be won or lost by monitoring tire pressure to maximize tire wear. Well - it's true of street tires as well. If attention is paid to tire pressure, tire longevity is the payoff. And, as expensive as tires for a Corvette can be, there is absolutely a benefit to paying attention to this, not to mention that the car can ride, handle and brake better too.
Former CF Member Evil-Twin must be credited with this information, I learned it from him. If you're watching.....thanks, Bill!
Old Aug 8, 2006 | 11:19 AM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
BINGO!
Old Aug 8, 2006 | 01:16 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
...Evil-Twin was right on the money with this one...he said 30-31 hot and that means 26-27 cold(in the summer or depending on where you live and adjustment for the winter or cooler ambient temps)....sounds strange but it is the absolute truth about C5 tires...30 cold could mean 34-37 hot(in the summer), depending on the ambient temperature and thats too much...unless you enjoy seeing the centers wear like crazy
Old Aug 8, 2006 | 02:41 PM
Dave68's Avatar
Dave68
When I still had the OEM tires, I would fill to 30 psi cold. The center of each tire would wear faster than the inner and outer areas. I then started to make sure that when hot, no tire pressure exceeded 31 or 32 psi. This seems to be working very well.
Old Aug 8, 2006 | 03:29 PM
Bill Dearborn's Avatar
Bill Dearborn
I fill to 30 lbs cold summer or winter. No unusual tire wear due to pressure. I do get some cornering wear on outside edges of the front tires but the rears wear evenly. GM recommends the cold pressure since that is the one that can be monitored correctly and is correct for all seasons. Street tires just do not get very hot under normal operating conditions. Just put your hand on the tread of a street tire driven at 75 mph for 2 hours and then put your hand on a race tire driven at the limit for a half an hour. You will be able to touch one and not the other. Keeping the cold pressure lower in the summer just generates more heat in the tire which increases pressure more. Tire pressure changes about 1 lb for each 10 degrees of atmospheric temperature. So if you fill your tires to 30 lbs cold when the air temp is 60 and then check them after they soak in an air temp of 80 they will read about 2 lbs higher. The cold temp reading of 30 when temps are 80 will read 28 when the temps drop to 60. GM did a lot of testing to find out the best cold temp setting for all seasons that will give the best combination of performance, endurance and safety.
Bill
Old Aug 8, 2006 | 03:48 PM
thisMSGgood4me
Bill
with you 100% Bill. If that's what the experts at GM recommend, that's good enough for me. Why try to second-guess their expertise? Besides, hasn't it been suggested by some here that we follow GM's recommendations, for example, using the OLM in determining when to change the oil and filter?
To Tire Pressure
Old Aug 8, 2006 | 04:03 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Bill
With all due respect, I see nowhere in the above explaination any consideration for the pavement temperature that also effects tire pressure. Aspahlt gets to 140-150 in the summer months and raises the tire pressure in addition to the ambient air temperature. Thats why just going by air temperature is not good enough and should be adjusted for when considering how much pressure the tires should be at cold or hot. GM gives generic estimates on the door for tire pressure....Evil-Twin was a GM engineer for 30+ years and he definately know what he is talking about especially when talking about tire pressures.
FYI
Originally Posted by Evil-Twin
OK here is the answer to your question... and you can take this to the bank...
You Runflats work best at around 30/31 psi hot...
It is not as difficult as the wannabe's would make it out to be.,..
there is little variance in road temps in the winter, spring and fall.. in most areas..
20f to 50 F... is common..
The real tire tune is done in the summer when cold tires in the morning are sitting on 50 F surfaces...
In the summer you can take a cold tire out on a blacktop surface reaching temps of 140F to 150F.
This will take your tires up in the 36 to 38 psi range...
So in the sumer when you are seeing 85 and 90 degree days, you need to lower your tire pressure to a point that when you actually using the tires they are not in the 35 to 38 psi range..
I didn't check where you live,,, but tire tuning is based on where you live and how hot it gets...
The sticker on the door is generic and covers a multitude of sins..Its like a tire alignment.. ther is a + - tolerence for all the specs. but there is perfect spot...it is called the mean... a typical spec will be 3 degrees plus three, minus 2... but the perfect number is 3 degrees... same with tires. Sure they will work at 30 psi cold, but they will work better if tuned to the perfect spot.
To get the most out of your car, having the right footprint will give you the best miles per gallon and the best tire life...
Ever since I started doing what Evil-Twin has suggested...I have seen no abnormal tire wear and better gas milage...
Feel free to choose which method is best for you
Old Aug 8, 2006 | 04:40 PM
thisMSGgood4me
Forgive me for asking but how do you get better gas mileage by inflating your tires with less psi than what's recommended? That doesn't make any sense to me.
Old Aug 8, 2006 | 04:42 PM
Cole's Avatar
Cole
GM quoted the recommended tire pressure for the standard tires issued with the car - usually Goodyear Run Flats. However, tire technology changes and many Corvettes are using non - runflats, ala Z-06, and aftermarket runflats and non-runflats. I am using Firestone Wide Ovals -non runflats- and found that I improved handling and ride considerably by adjusting TP up a bit. I started at 30, went up a pound until 34 pounds and then backed down in 1/2 pound intervals until I settled on 32 1/2 pounds as the best compromise for ride and handling in general use. I have not needed to adjust for track or dragstrip, but expect that TP's would need to be played with for both those environments.
As far as the measurment itself, my TP guage is digital - actually, I have two that are digital and the readability is +- 1/2 pound. I won't discuss accuracy as that is a whole subject unto itself. My primary guage matches up with the DIC almost exactly which provides me with good assesment of my set pressures and enables me to add air as needed and maintain my handling characteristics.
So, the designer may have worked closely with the tire vendor for the nameplate guidelines, but each of us needs to be aware and adjust TP's that fit our car, tires, and driving environemen. Its not a sophistiicated thought process, just simple common sense.
