Outside temp. reading wrong....
Old Aug 13, 2006 | 03:36 PM
MyOwn69's Avatar
MyOwn69
Default Outside temp. reading wrong....
Mine says 68 and I KNOW it is over 80. What's wrong?
Old Aug 13, 2006 | 03:40 PM
GOZ2FST's Avatar
GOZ2FST
Maybe it's time for a new temp sensor. They're cheap - like $10-$15.
Old Aug 13, 2006 | 03:54 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Seems to me 68 is what they read when they go bad - it is located up in the front end.
Old Aug 13, 2006 | 03:57 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
It sticks out into the airstream that runs into the radiator.. Look on the passenger side of the middle of the car. It sticks right out pointing towards the drivers side. It's black, covered in plastic and not quite a 1/4 inch in diameter and only an inch or so long with a wire running out the back of it... You'll see it.
Old Aug 13, 2006 | 06:16 PM
MyOwn69's Avatar
MyOwn69
Yep - there it is!
So, you guys are saying that I'll need to replace it - right?
Like Rosanne Rosannadanna said, "It's always something!"
Thanks for the help!
Old Aug 13, 2006 | 08:27 PM
garypz53's Avatar
garypz53
Default another possible
That is about the temp it says when the connection to the sensor is open.
There could be a break in the wiring.
I would probably put a 100 ohm resistor across the pins first to see if the temp changes.
Old Aug 13, 2006 | 08:30 PM
SpeedUp's Avatar
SpeedUp
anyone have a part # handy ?
Old Aug 13, 2006 | 10:19 PM
MyOwn69's Avatar
MyOwn69
HEY!! I'm supposed to be the one asking that!!
Thanks - I was thinking the same thing!
(Oh, by the way, just noticed the "avatar!" )
Old Aug 14, 2006 | 12:13 AM
Hope the sensor is all that it is. Good luck with the repair.
Old Aug 14, 2006 | 03:26 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
TTT for part number!
Old Aug 14, 2006 | 03:30 PM
Bounty Hunter 6
I found this on Fred Bean's site. It is the ambient temp sensor, right?
http://www.trademotion.com/partlocat...02&catalogid=1
Old Aug 14, 2006 | 07:34 PM
MyOwn69's Avatar
MyOwn69
Oh, Gawd, there goes my headers mod for another month!!!
Old Aug 15, 2006 | 04:47 PM
OvrEagR's Avatar
OvrEagR
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Old Aug 15, 2006 | 05:38 PM
diyguy's Avatar
diyguy
Default How does this Work? What is sequence?
I am getting all kinds of weird errors on mine. Anyone acutally know the 'flowchart' of how it works, updates itself, how often, etc?
I already replaced one sensor, and jus the other day put some dielectric grease on the connector (didn't change anything).
One minute I can be looking at a temp near accurate, and next thing it's 20 degrees off on the low side. Then one thing I've noticed is driving one certain route every day, the temp indicator starts moving upward every day at exactly the same spot in the road, which is very odd!
Would help to know how this 'system' works.
To Outside temp. reading wrong....
