A/C problems
Old Aug 14, 2006 | 05:11 PM
metsnet's Avatar
metsnet
8th Gear
Default A/C problems
I have a 99 a4 with dual zone A/C. The problem is that when I used to change the air from fresh air to recalculated air the A/C would get colder and blow stronger. Now when I change settings there is no change in air temp or flow. It seems that the A/C is stuck on fresh air. Living in Arizona this is a big problem. Any help would be appreciated.
Old Aug 14, 2006 | 05:59 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Chances are it is the air inlet valve actuator. It is basically a trap door with a motor on it that allows you to change inlet of air from outside to recirc etc.
Old Aug 14, 2006 | 08:50 PM
metsnet's Avatar
metsnet
8th Gear
Where can I get an air inlet valve actuator?
Old Aug 14, 2006 | 10:37 PM
Qcksilverc5's Avatar
Qcksilverc5
I would check the freon first if it were me-----have you serviced the a/c recently?
Old Aug 15, 2006 | 10:56 AM
RichieRichZ06
St. Jude Donor '08
dealer. I would have somebody diagnose for sure due to having to pull dash apart to get there.
Old Aug 17, 2006 | 12:21 PM
metsnet's Avatar
metsnet
8th Gear
I figured out how to solve the problem… at least for a year. Ill going to go to Canada for 2 weeks and hopefully it will cool off some before I get back! I know it’s not the most effective method but I think it will work. Thanks for the help guys. I will have the Freon checked when I get back and if that’s not it ill be pulling the car apart.
To A/C problems
