Flameball install, any advice?
Old Aug 15, 2006 | 12:23 PM
thraka's Avatar
thraka
Default Flameball install, any advice?
I know a lot of guys here have a flameball shift ****. Anyone have some specific info on exactly which wire you tapped to get your power, how you got the shifter boot to sit higher, etc?
Old Aug 15, 2006 | 01:22 PM
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
I tapped into the fog light switch for power. I leave the switch turned on all the time, when the lights come on, the flameball comes on
Old Aug 15, 2006 | 01:37 PM
BlueDream's Avatar
BlueDream
I found one of th wires for the HVAC and tapped into it. Searched for one that activates with the parking lights so that whenever it is dark enough to need the parking lights or headlights, the flameball will light up as well.
Old Aug 15, 2006 | 02:06 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
Think i used the instructions here. http://www.cau-llc.com/flameballins.htm
A search for "flameball instrucitons" in the C5 archives yeilds a whole page of references.
Old Aug 15, 2006 | 02:21 PM
thraka's Avatar
thraka
Thanks, bro, that's just what I needed! Obviously I am doing something wrong in my searching. I don't get the references you came up with when I search the whole C5 section. I am not seeing an archive section. Would be good to know where to find it!
Old Aug 15, 2006 | 04:48 PM
QuikZilver's Avatar
QuikZilver
I tapped into a brown wire that illuminates the traction control button. It was the easiest place to get power and was right there. You don't have to yank everything else apart.
Old Aug 15, 2006 | 05:06 PM
jodfit's Avatar
jodfit
St. Jude Donor '07
Old Aug 15, 2006 | 09:56 PM
Bobs dream's Avatar
Bobs dream
That's what I did.
Old Aug 15, 2006 | 10:08 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Originally Posted by Bobs dream
That's what I did.
FLAMEBALL!!!!!
To Flameball install, any advice?
