Rocker Panel Glue
Old Aug 17, 2006 | 02:47 PM
HollywoodVette's Avatar
HollywoodVette
Default Rocker Panel Glue
Would any of you guys here happen to know what kind of glue chevy uses to glue the corvette body to the frame?? I wanna make sure and use the rite glue for the rocker piece im replacing... any help ?? thanks in advance guys sam...
Old Aug 17, 2006 | 03:35 PM
HollywoodVette
ttt..... any help guys??????????
Old Aug 17, 2006 | 03:54 PM
Bill Dearborn's Avatar
Bill Dearborn
From the Service Manual:
Apply structural adhesive GM P/N 89020330 (Canadian P/N 8902332) to inner edge of rocker and clamp in place until adhesive cures.
Here is the Table of Repair Materials although it will not look like a table in the post.
Repair Materials - Rigid Plastic Part
Thermoset Plastic Type
Type of Repair
Recommended Repair Material
Availability
Sheet Molded Compound (SMC), RIM rigid plastic parts
Cosmetic filling
Sikkens Polystop LP™ or equivalent polyester repair putty use Fusor 114 Plastic Finishing Adhesive = 3 min.
Refer to a local paint supplier 1-800-234-3876
Most rigid plastic parts
Cosmetic filling repair
GM Goodwrench® Plastic body repair adhesive GM P/N 89020331 (Canadian P/N 89020333) Fusor® 100EZ Plastic body repair adhesive = 40 min. Refer to ** at the bottom of the page.
GM Dealer/Retailer
Refer to local paint supplier 1-800-234-3876
Adhesive bonding
GM Goodwrench® Plastic bonding adhesive GM P/N 12378568 (Canadian P/N 88901676) = 5 min. Dynatron Dyna-Weld Plio Grip® or Fusor® 148 urethane adhesive = 5 min. Refer to * at the bottom of the page.
GM Dealer/Retailer
Adhesive structural bonding
GM Goodwrench® Plastic structural adhesive GM P/N 89020330 (Canadian P/N 89020332)
Fusor® 127 EZ Structural Adhesive = 50 min. (OE Structural Boning) Fusor 120 = 45 min. GM P/N 12345726 (Canadian P/N 88901676). Refer to ** at the bottom of the page.
GM Dealer/Retailer
US Chemical™ and Plastic System 2000 Structural Adhesive
P/N 82007 = 30 min.
P/N 82014 = 9 min.
Refer to local paint supplier or US Chemicals customer service 1-800-321-0672
SRIM most rigid plastic parts
Cosmetic repair; Adhesive bonding
GM Goodwrench® SRIM™ repair kit GM P/N 12378523 or
SIA™ Adhesives, INC. SRIM™ repair kit P/N 30208030001 adhesive 200 ML TUBES P/N 30208020001 50 ML TUBES P/N 30208010001
SIA Adhesives, INC. customer service 1-330-374-2468
Tools Required
* Applicator # 285-LRD-300
** Applicator # 285-LRD-301
Kent-Moore 1-800-GM-TOOLS EXT. 5
Bill
Old Aug 17, 2006 | 05:06 PM
HollywoodVette
Type of Repair
Availability
Cosmetic filling
GM Dealer/Retailer
Adhesive bonding
GM Dealer/Retailer
GM Dealer/Retailer
P/N 82007 = 30 min.
P/N 82014 = 9 min.
Tools Required
Bill
thanks for the help i appreciate it... now i gotta figure out wich one i need.
To Rocker Panel Glue
