Throttle position sensor
Old Aug 19, 2006 | 03:30 PM
Dr.Jeff's Avatar
Dr.Jeff
Default Throttle position sensor
Hi: Could not start my 98 ,auto trans, 59000 mi, last night.Would bearly crank,low voltage message,DRLs out,etc. Started OK today. My mechaniic said it could be the throttle position sensor.Threw this code,but today the car is fine.PS, three weeks ago had to replace the alternator(GM) Any thoughts? Thanks.
Old Aug 19, 2006 | 07:32 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Battery time for an Optima Red top
Old Aug 19, 2006 | 07:42 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Battery is the most likely culprit.
How old is it?
Old Aug 19, 2006 | 07:48 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Pull the codes to see what you have
Old Aug 20, 2006 | 11:30 AM
Dr.Jeff's Avatar
Dr.Jeff
How old is it?
Hi: Thanks for the suggestion. Not sure, as it was installed by the previous owner. However, we did a "load test" and it checked out OK. Perhaps, I should replace it anyway. (There is an Optima red in the vehicle)
Old Aug 20, 2006 | 11:31 AM
Dr.Jeff's Avatar
Dr.Jeff
Default Battery
How old is it?
Old Aug 20, 2006 | 01:21 PM
patton's Avatar
patton
St. Jude Donor '09
i bearly cranked over and passed a load test ? no problems before ? i assume they charged it before testing can you remove the tops for a spec. grav. test.
Old Aug 20, 2006 | 03:40 PM
Dr.Jeff's Avatar
Dr.Jeff
Hi: Will do. Thanks!!
To Throttle position sensor
