I gotta think that if you search for "demon key" you'll find plenty of info. Prying is best. DO NOT YANK on it... you'll get nowhere...
Some say putting some WD-40 or similar helps to aidein the removal but definately pry on it carefully. Use a locking pliers and pry on the bottom of them using the top of the **** as a base to pry against. Cover it with a heavy rag before prying.
Some have also used a vise grips and made a sliding hammer out of the adjusting screw by replacing it with a longer screw and a small weight to slide on it for a way to pull the key out. That seems like a good way to me.
Clamp some vice grips on the demon key, and then while pulling and rocking, tap (bang) the side of the vice grips with a hammer. Will take you a couple but it will come out.
This was the only method that worked for me. Bang a hammer hard into the vice grips, with an upward motion. Vibration and upward stroke will eventually get it moving. Be patient.
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Doesn't the A4 **** just have a staple holding it in place...at least thats all mine had. The staple is located at the bottom of the **** on the side facing the radio...put it in the 1st gear position and you'll be able to see it
yea vice grips and a screw driver through the vice grips so you can slap the vice grips upward. . . make sure you have the top off the car in case it gets away from you . . having a third hand or a buddy makes it easier
