cold air intake?
Old Aug 20, 2006 | 04:57 PM
elctroman's Avatar
elctroman
Default cold air intake?
just got my stock 2000 a4 and im going to carlisle next week.will there be anyone selling them and which 1 should i buy and whats a good price.this will be the first mod of many
Old Aug 20, 2006 | 05:39 PM
Stonecutter908's Avatar
Stonecutter908
We have the same agenda ...
Old Aug 20, 2006 | 06:06 PM
kingsey's Avatar
kingsey
id like to know the best one most HP gain.
Old Aug 20, 2006 | 06:13 PM
rgtkst's Avatar
rgtkst
i have the breathless performance vortex and like it. simple, looks good, the clear one i can see the filter for cleanlyness. i dont know about the power advantage. maybe just a few hp.
Old Aug 20, 2006 | 06:17 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
There are a lot of different cold air intake systems available. There are also as many opinions on which ones are the best. I am by no means an expert on the topic, but I'll post some that I know of and what I know of them. Hopefully others with experience will chime in.
Callaway Honker: Very nice unit, expensive. No experience with it.
Vararam B2: Some folks complain about the worksmanship of the product but report great results.
Vortec Rammer: I have one. It came with my car. It works well. Reasonably priced unit.
K&N Dual Cone Intake: Don't buy the ones from ebay. Some members love them.
Donaldson Black Wing: Nice unit. No experience with it.
Halltech C5 Stinger: Nice unit. No experience with it.
These are just the units that I can think of. Hopefully someone else will add to this thread.
Good luck
Old Aug 20, 2006 | 06:28 PM
time4prime21's Avatar
time4prime21
BLACKWING FOR SURE!.....Pricey but I really could tell the difference in my 97 coupe a4....I just got my new 04 6spd two days ago and I need to buy a intake as well....and im going with the Blackwing again...looks good in there and good results..esp with the A4! see you at Carlisle as well....Im 20mins from there..so pm me if you need the secret way in to avoid all the traffic!
Old Aug 20, 2006 | 07:05 PM
corvette Mark's Avatar
corvette Mark
Vararam=
Old Aug 20, 2006 | 07:28 PM
BanditDude's Avatar
BanditDude
Originally Posted by corvette Mark
Vararam=
Some don't like the fitment, but there are ways around that. Great product.
Old Aug 20, 2006 | 07:31 PM
Dave68's Avatar
Dave68
For those of you who live in California, think twice about the Vararam, as it can be a royal pain to install/uninstall/reinstall for smog tests. If you live in a state that doesn't have visual inspections, then take a look at the following (grouped by cold air and non-cold air, but in no particular order) and my comments, if any:
Vararam: Brings cold air in through the fog light panel area to a panel-type filter. Owners have had good luck with system on the dragstrip, but plan on spending hours to install and a bit more to get everything lined up well. Downside: Eliminates engine bay-cooling air that would've come in from the fog light panels (Z06 or coupe/vert with opened-up panels), so the engine bay may end up being toastier, especially if you add headers later. $300-$400
Vortech Rammer: Brings cold air up from in front of the radiator and into an enclosed box. Its filter is quite a bit smaller than the Halltech Warhead or Blackwing unit. $250
Callaway Honker intake system: This one relocates the MAF so that it is just in front of the throttlebody. It directs cold air from underneath and costs about $500. I believe this unit is 50 states legal (smogwise). Excellent design and quality. If cost is no object, this bad boy should be at the top of your list.
K&N FIPK: This is more of a semi-cold air system, as the cold air intake opening is more of a slit. Its filter endcaps are carbon fiber. However, it is configured similarly to the Halltech Stinger-R and is 50-states legal. $350
Warm air systems: (Easy installation)
Halltech Stinger-R: Not only contains the massive Warhead filter, but also includes a larger-than-stock airbridge and smooth throttlebody coupler. For $300.00 or less, this system represents one of the best bangs for the buck. Fortunately, for about $40, you can add cold air induction. See my procedure at http://www.conceptualpolymer.com/corvette_c5_corner.htm
Halltech Stinger SSM – 2001-2004 C5 only (new!): This intake system features an even larger filter than that of the Stinger-R, TRAP, and Blackwing. $400
Blackwing: Includes just a large filter, but an excellent one at that. Its cost is close to that of the Stinger.
Volant Twin Cone: This system gives you more open filter surface area than any stock box does and is well suited to an engine bay that gets cold air in from the fog light panels, as the filters are more or less in the air flow path. $265
2002+ Z06 airbox cover: A larger opening allows more air to be drawn in through the filter. Expect up to a 5 RWHP gain from this simple swap. $50
Zip-tie: An easy and inexpensive mod (eliminates the OEM box’s upper lid), but its sealing ability (in the pics I've seen) is questionable at best.
How good are they? My experience has shown that most will bump up RWHP by at least 10. The advantage of having cold air is that power will not be "dialed down" under normally hot underhood (and intake air) conditions. You could easily lose 10 HP with a warm air system after engine bay temps rise during slow-moving conditions. Cold air prevents this from happening.
Old Aug 20, 2006 | 08:16 PM
elctroman's Avatar
elctroman
thanks for the info ,now just 1 more ? is the blackwing cold air?
Old Aug 20, 2006 | 08:18 PM
Dave68's Avatar
Dave68
....not unless it is "supplemented" by my cold air mod OR the Ice Box addition.
Old Aug 20, 2006 | 08:25 PM
teejake's Avatar
teejake
Lifetime Supporting Gold
I have Breathless performance on my 2004, installed at same time as GHL exhaust and X pipe so hard to say how much of the performance difference was the cold air intake but the combined effect was very noticeable.
Old Aug 20, 2006 | 08:44 PM
elctroman's Avatar
elctroman
dave on a sclae of 1-10 how hard is this job?
Old Aug 20, 2006 | 11:39 PM
Dave68's Avatar
Dave68
I would give it a 5, It's easier than installing a Vararam and on par with installing most other CAI systems. If you're a bit on the non-technical side, having a buddy help out is a good idea. I've helped a couple of people do this mod. It takes about 3 or 4 hours if you take your time and a couple of hours if you've done similar work.
Dave
Old Aug 21, 2006 | 02:38 AM
oahuyahoo's Avatar
oahuyahoo
Have the Vararam sitting in my garage but have changed my mind as water just gets too deep here on the roads. FWIW 99.99% chance will install Callaway Honker.
Old Aug 22, 2006 | 02:38 PM
I installed a Blackwing on mine and have been happy with the performance. Easy to install and looks great.
Old Aug 23, 2006 | 12:01 AM
JonCR96Z's Avatar
JonCR96Z
Sorry to jack the thread, but
Whats the difference between the 97-00 and the 2001+ Volant twin cone?
Old Aug 23, 2006 | 12:09 AM
jrose7004's Avatar
jrose7004
I'll bet that everywhere you look there will be intakes for sale!
To cold air intake?
