removing old window tint
Old Aug 21, 2006 | 08:50 AM
BosqueVette98's Avatar
BosqueVette98
Default removing old window tint
What is the best method for removing old 'foggy' looking window tinting?
Thanks!
Old Aug 21, 2006 | 09:18 AM
itlfly's Avatar
itlfly
Heat gun and a careful peel. Then clean residual adhesive with an adhesive remover like Goof Off. Not too hard, just take your time peeling it off so it stays in one piece.
Old Aug 21, 2006 | 09:21 AM
DeeGee's Avatar
DeeGee
Done it on the Camaro. Just gently peeled it off.
The adhesive residue was a real PITA to get off. I used and adhesive remover similar to goo gone to finish the job.
Old Aug 21, 2006 | 11:00 AM
GWurst's Avatar
GWurst
http://www.tintdude.com/remove.html
Works great.
Old Aug 21, 2006 | 11:24 AM
hotwheels57's Avatar
hotwheels57
Fill a spray bottle with ammonia and spritz it onto the film, let it do its thing for a few minutes. Protect the upholstery leather just in case. The tint will come off, hopefully in a full sheet after the ammonia loosens the adhesive. Then use ammonia and straight edge razor blades to remove the remaining adhesive on the glass. Ammonia is the natural killer of window tint, that's why they warn you not to use window cleaners with ammonia.
Old Aug 21, 2006 | 12:07 PM
BosqueVette98
Thanks y'all!
To removing old window tint
