Battery Tender Question
Old Aug 22, 2006 | 01:17 PM
JC in XTC5's Avatar
JC in XTC5
Page 6-32 inthe Owners Manual (2000):
Vehicle Storage
If you’re not going to drive your vehicle for 25 days or more, remove the black, negative (-) cable from the battery. This will help keep your battery from running down.
This is due to the norman parasitic drains of the various computers in the car. The Battery Tender will prevent the battery from draining.
Old Aug 22, 2006 | 01:26 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Originally Posted by HD Rider
Are there any issues with disconnecting the battery cables for a couple of minutes while attaching the battery tender yoke wires, such as needing to reconfigure some of the computer settings, etc?
there will not be a problem. you will not even lose your radio stations...
Old Aug 22, 2006 | 02:38 PM
hotwheels57's Avatar
hotwheels57
The BATTERY TENDER PLUS maintenance chargers each come with two types of connectors for the battery. They're fused leads about 12" long with a male/female quick disconnect which connects to the BATTERY TENDER PLUS.
There is a lead with alligator clips to connect to the battery terminals and a lead with ring terminals. I selected the ring terminals for my '04 Z16. I just removed the battery cable nuts under the red/black plastic insulators to attach the ring terminals. On another car, I use the alligator clip lead. Both stay on the cars when I disconnect the BATTERY TENDER PLUS.
Old Aug 22, 2006 | 03:47 PM
C.T.'s Avatar
C.T.
Default Battery Tender Jr. not safe?
Originally Posted by ronnie948
Get the regular battery tender. It is a little more expensive but much safer then the Jr. model. You can leave the regular hooked up for up to a year. It will reset if the electric goes out. It is pretty much fail safe as the Jr. is not.
Just curious - why is the Jr. unsafe?
I've had one on my '57 full time for 3 yrs. now, works great, and never a problem. Also plan to get another for my '04 unless there's an issue...
Thanks.
Old Aug 22, 2006 | 04:20 PM
hotwheels57
...the BATTERY TENDER JR. is a three step maintenance charger, five year warranty @ $39.95. The BATTERY TENDER PLUS is a four step maintenance charger, ten year warranty @ $59.95. Look at their website, batterytender.com for the specifics.
I'm not sure myself why the BATTERY TENDER JR. would be considered "unsafe", but I've only used the BATTERY TENDER PLUS.
Old Aug 22, 2006 | 04:24 PM
tommybilt's Avatar
tommybilt
Default think about this
Ever notice how if you charge your cell phone every night regardless if it needs it or not that down the road it wont hold a charge? Some batteries develope a memory. Is this true with a car battery?
Old Aug 22, 2006 | 06:57 PM
Merlin02's Avatar
Merlin02
Originally Posted by Lightgomez
Has anyone else had any experience with Schumacher?
I have used a Schumacher Battery Companion for the past four years with no problems whatsoever. $22.00 at Auto Zone.
Old Aug 22, 2006 | 10:08 PM
moserbe's Avatar
moserbe
I also use the battery tender plus during winter storage. I drive the car as much as possible in the spring, summer, and fall so the battery needs no assistance.
Old Aug 23, 2006 | 05:58 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I have put my 99 on a battery tender whenever I know I'm not going to drive it the very next day. I know that's overkill but vettes are so inter-dependent on the various control modules, etc, that any drop in battery power seems to drive the systems crazy. The DIC throws all kinds of seemingly unrelated codes, etc, because of it. As a consequence, I'm still using original OEM battery (soon to be switched out as a precaution).
Old Aug 23, 2006 | 08:01 AM
C5XTASY's Avatar
C5XTASY
Same here. And, as general input to this thread, that Schmacher maintainer will work fine, BTW. The same with the Sears, I'm sure. No reason to spend big bucks. The Schumacher (I have two of them I purchased at Fleet Farm), have been working great for the past three years.
Ed
Old Aug 23, 2006 | 09:28 AM
billiardcue's Avatar
billiardcue
My experience with Schumacher was pulling him out of his first wrecked funny car in 1967 at Winston-Salem dragway.
Schumacher is the world's largest producer of battery chargers, they must be doing something right.
Don is also an avid hot rodder - 2 top fuel dragsters, 4 top fuel funny cars, 2 pro stock motorcycles and 2 pro stock cars. If you are into drag racing support other drag racers.
Old Aug 24, 2006 | 02:13 PM
PARTS DESTROYER's Avatar
PARTS DESTROYER
Obviously by this question I don't have one. But am getting one today. Can you close the hood with the tender working or do you leave it up...
Just wondering 4 now..
Old Aug 24, 2006 | 03:11 PM
  #33
LarryW's Avatar
LarryW
I connect my Battery Tender Plus using a cigarette lighter adapter plug so I never have to pop the hood to make the connections (I just leave my driver side window cracked an inch or so to route the cable Works like a champ
If you go with the Schumacher or some other brand, check and see if they provide a similar adapter.
Larry
Old Aug 24, 2006 | 05:32 PM
  #34
hotwheels57
The lead on the BATTERY TENDER PLUS is long enough to extend over the fender and leave the hood unlatched for maintenance charging.
Old Aug 24, 2006 | 05:44 PM
  #35
peter p's Avatar
peter p
I know that a lot of people use the Delran Battery Tenders around here, but, have to keep in mind one thing these tenders don't do...keep the plates clean and free of sulfate crystals (that form from the sulfuric acid) that ultimately do in the battery over time. Plate sulfation occurs continuously over the life of a battery even as you charge it.
The only way to stop and reverse the process and keep the plates clean,is to use a charger with pulse technology to reverse the formation of these sultate crytals.
The only charger on the market that currently offers this technology is the VDC Electronics Battery MINDer Plus: http://www.vdcelectronics.com/batteryminder_12117.htm. Just a consideration if you all want to keep your batteries in tip top shape.
Old Aug 24, 2006 | 05:52 PM
  #36
hotwheels57
...I'll repeat what I've mentioned in the past. I know this discussion isn't about OPTIMA batteries, but it's the only battery I'll use in any of my personal cars as well as my past "company" vehicles.
I participated in testing of the OPTIMA red top batteries provided by the manufacturer to my employer, prior to their availability to the general public. I've always used a DELTRAN BATTERY TENDER PLUS on the OPTIMA batteries I've personally owned. I've never used a BATTERY TENDER PLUS on any oem lead acid batteries. I used to replace those batteries every two years in AZ climate.
The longest lasting OPTIMA battery I had was seven years before I sold that '55 210 sedan hotrod to another party. To my knowledge the owner of that car is still using the same OPTIMA battery with a BATTERY TENDER PLUS which I recommended to him.
