"Computer Aided Gear Selection", 1-4 shift
Old Aug 25, 2006 | 08:18 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Originally Posted by The Nuts
, or you can be cheap like me and install a $1 resistor from radio shack, works great and no more annoying 1-4 shifts!
Cheap????....More like crazy like a fox. Thats a great alternative.
Old Aug 25, 2006 | 08:27 AM
Z06Aggie's Avatar
Z06Aggie
....or do what I do. If you ever see the light come on, push a little harder with your right foot. It will go away.
Old Aug 25, 2006 | 08:34 AM
zonsolo's Avatar
zonsolo
I have yet to get the bypass, and it only rears its ugly head when I'm letting someone else drive, or I'm following another slow moving car around a corner.
I am planning to order one though, just too lazy to shop for it.
Old Aug 25, 2006 | 08:43 AM
Corvette Monkey's Avatar
Corvette Monkey
I like CAGS. It saves gas and wear on the clutch and engine. I actually use 2-5 as often as I launch with 1-4 on stock gears. CAGS is only there when you're loafing, so why not?
Old Aug 25, 2006 | 08:53 AM
Arnie Guitar's Avatar
Arnie Guitar
Because you never lug an engine, any engine, that's why.
I installed the kit, and it feels great to drive it like a normal car.
Old Aug 25, 2006 | 10:51 AM
fdxpilot's Avatar
fdxpilot
Originally Posted by Joel B.
So...does the CAGS physically prevent the shifter from shifting into 2nd or 3rd?
Yes, a solenoid physically blocks it. The cags eliminator disconnects the solenoid, and puts a resistor on the computer side of the plug that makes the computer think the selonoid is engaged.
Old Aug 26, 2006 | 12:01 AM
hardtop's Avatar
hardtop
Why not you say?
I got caught a couple of times where I was easing into traffic to make a left turn. I would time it were I could roll up to a left turn in first, to let a car or two pass. After the cars pass begin my turn and shift to second. Second is blocked and I am forced into fourth with oncoming traffic. Push the pedel to the floor and the Vette strugles out of the way. Yeah, I should have stayed in first but it was too late, I had already made the decision to shift and couldn't find the time to push the clutch back in and shift back to first.
Old Aug 26, 2006 | 11:40 AM
craig04c5's Avatar
craig04c5
Originally Posted by hardtop
Why not you say?
This happened to me also. I was shifting out of first when it happened so I had no choice. I almost got hit. I got the skip shift eliminator shortly after.
Old Aug 26, 2006 | 11:56 AM
fdxpilot's Avatar
fdxpilot
Why not you say?
Yeah, it always happens at times like that. Very much worth the $20-30 dollars. Had one on my vette within a week of purchase.
Old Aug 26, 2006 | 12:16 PM
Z28TOZO6's Avatar
Z28TOZO6
The cags is one of the things on our cars that helps circumvent the gas guzzler tax. It's there as a fuel saver. With that said, get a CAGS eliminator asap! It is a pain in the A$$!
Old Aug 26, 2006 | 12:30 PM
HummelS's Avatar
HummelS
It's never been a problem for me - don't shift out of 1st until you hit 2K rpm & it won't be a problem.
Lots of people bitch about it, but it's better than the alternative, which would be paying a gas-guzzler tax.
Old Aug 26, 2006 | 02:04 PM
Nitro Junkie's Avatar
Nitro Junkie
The CAGS eliminator is a lot cheaper than a gas guzzler tax. Buy it and be done with it.
Old Aug 27, 2006 | 09:01 AM
  #33
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Originally Posted by byte_me
Yes- The C5 also has this...if you are below (I want to say 2000 RPM) it will force you to go to 4th from 1st- There is a simple $20 inline harness you can buy to defeat this. Most of us 6 speeders have this installed as the CAGS is a PITA. Keep in mind, even with the CAGS defeat installed, the 1st to 4th light on the gauge cluster still comes on...but you can use any gear as you wish...
I installed the CAGS eliminator shortly after buying the car and it also eliminated the 1st to 4th light on the gauge cluster.
