[Z06] "Low Oil Level"
Old Aug 26, 2006 | 10:38 PM
LS6 Z06's Avatar
LS6 Z06
Default "Low Oil Level"
I have a 04 Z06, i received this message 3 days ago, checked the oil and was a quart and a half low. I bought the car with 11,500 miles and it now has 14,024 miles on it. I changed the oil yesterday since i was not to sure what kind of oil was in it before and didnt what to chance mixing them. I made sure it's filled and i am still getting this message? Any ideas on what the problem may be? Thanks
2004 Millennium Yellow Chevrolet Corvette Z06
Old Aug 26, 2006 | 10:45 PM
20Zo604's Avatar
20Zo604
reset the the message
Old Aug 26, 2006 | 10:47 PM
LS6 Z06's Avatar
LS6 Z06
I reset the oil life meter right after the change. The next time i started it up the message came up so i reset and thought i was fine, but everytime i start up it comes up, when i rest it, it comes up while i am driving.
Old Aug 26, 2006 | 10:56 PM
OutlawDon's Avatar
OutlawDon
How much oil did you put in?
Old Aug 26, 2006 | 11:34 PM
Z06-Goose's Avatar
Z06-Goose
The only time I've had that message come up on my Z06 -even when it has plenty oil- is when I leave it parked on an incline, or steep driveway.
Goose
Old Aug 27, 2006 | 08:27 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Make sure you put in the correct oil quantity and then check it on the dipstick. If all this was done correctly you may have a bad oil level sensor
Old Aug 27, 2006 | 12:12 PM
FlyinNOE's Avatar
FlyinNOE
I had it happen. I had to replace the sensor. Not a huge deal.
Brian-
Old Aug 27, 2006 | 12:20 PM
LS6 Z06's Avatar
LS6 Z06
I took it to a friend who owns his own repair shop and owns alot of Corvette's. He just bought an 07' Silver Z06 to and to his stable. I will check back with him tomorrow to see how much oil he put in it, since he knows Corvette's i would assume he put the correct amount in, so it might very well be the sensor. Thanks for the reply's guys .
2004 Millennuim Yellow Chevrolet Corvette Z06
100% Stock!...........For Now.
Old Aug 28, 2006 | 10:35 AM
MungoZ06's Avatar
MungoZ06
St. Jude Donor '10-'11
The correct amount is 6 1/2 quarts.
Friend of mine had the same message on his 04 ... and yes, whomever changed his oil shorted him a quart.
I change my own, and put in 7 quarts ... no problem ... just rides in the "wings". Car usually ends up with 7 1/2 qts as I "top it up" when I go to the track and just leave it in until I change it.
Tip: You can reset your oil life indicator by bringing it up on the DIC, turning he key to the "on" position, and pumping the accelerator three times ... easier than whatever's in the manual.
HTH
To "Low Oil Level"
